[mapguide-users] Label Expressions - replaceall
Zac Spitzer zac.spitzer at gmail.com
Fri Aug 1 23:55:05 EDT 2008
that's really terribly explained, when I first saw "from-characterset"
with translate, I thought it was
something to do with code pages!
Translate( <text property >, <from-characterset >, <to-characterset >)
Would make more sense to humans as
Translate( <text property >, <from-string>, <to-string>)
I would like to see a fourth parameter, <repeat> 1 being the default,
0 all or x number of times
z
On Thu, Jul 31, 2008 at 10:22 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> ah, yep, strange name, that's why I missed it...
> turns out there's a bit more logic required to split a name nicely
> z
> On Thu, Jul 31, 2008 at 9:30 PM, Jackie C. Ng <jumpinjackie at gmail.com> wrote:
>> FDO has the expression function Translate( <text property >,
>> <from-characterset >, <to-characterset > )
>> Is this available in mapguide?
>> - Jackie
>> zspitzer wrote:
>>> Is there an expression with mapguide which can be used to do a replace
>>> all?
>>> I want to replace all newlines in a label with '\n' to split the words
>>> over multiple lines
>>> I couldn't see anything in studio
>>> z
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
>> View this message in context: http://www.nabble.com/Label-Expressions---replaceall-tp18748700p18752597.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
