[mapguide-users] stylize error MGOS 2.0.1
Andy Morsell
amorsell at spatialgis.com
Sun Aug 3 14:45:47 EDT 2008
I have the same problem after upgrading to 2.0.1 on a Windows / IIS / .NET
server. I get those messages frequently, but it seems to occur once
mgserver has faulted. Once a fault occurs, all subsequent server requests
will then result in the failing to stylize error messages, but no real clue
as to what caused the fault in the first place. I use pskill and psservice
from sysinternals.com to restart the service since it cannot be started from
the Windows Services control panel.
I'm currently testing a tool that Jason Birch originally wrote to check the
MG status to see if it will detect the failure when this occurs. I will
know after next time it fails which will probably a day or so. If it works,
it will automatically restart the service (using the above described
psTools). I'll write back as to the success once I know.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ary sucaya
Sent: Sunday, August 03, 2008 3:59 AM
To: Mapguide User
Subject: [mapguide-users] stylize error MGOS 2.0.1
Hello group,
Since i upgraded my MGOS into version 2.0.1, i often get HTTP 500 error. I
checked the log file and found stylze error (attached). I couldn't restart
Mapguide service. It failed to stop..
The error layer is an ecw layer, and and an sdf layer. Is there a workaround
for this problem?
Thanks
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080803/539623a6/attachment.html
