[mapguide-users] stylize error MGOS 2.0.1
isca
mapguide2007 at gmail.com
Mon Aug 4 07:25:07 EDT 2008
I am encountering this problem especially when using raster layers which is a
real problem in the MGOS software. I have no scheduled a daily job
restarting the MapGuide service and this seems help.
Andy Morsell wrote:
> I have the same problem after upgrading to 2.0.1 on a Windows / IIS / .NET
> server. I get those messages frequently, but it seems to occur once
> mgserver has faulted. Once a fault occurs, all subsequent server requests
> will then result in the failing to stylize error messages, but no real
> clue
> as to what caused the fault in the first place. I use pskill and
> psservice
> from sysinternals.com to restart the service since it cannot be started
> from
> the Windows Services control panel.
> I'm currently testing a tool that Jason Birch originally wrote to check
> the
> MG status to see if it will detect the failure when this occurs. I will
> know after next time it fails which will probably a day or so. If it
> works,
> it will automatically restart the service (using the above described
> psTools). I'll write back as to the success once I know.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ary sucaya
> Sent: Sunday, August 03, 2008 3:59 AM
> To: Mapguide User
> Subject: [mapguide-users] stylize error MGOS 2.0.1
> Hello group,
> Since i upgraded my MGOS into version 2.0.1, i often get HTTP 500 error. I
> checked the log file and found stylze error (attached). I couldn't restart
> Mapguide service. It failed to stop..
> The error layer is an ecw layer, and and an sdf layer. Is there a
> workaround
> for this problem?
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/stylize-error-MGOS-2.0.1-tp18797661p18809467.html
