[mapguide-users] How do i load raster in MGOS 2?
wkhattak
Wajid.Khattak at keynetix.com
Tue Aug 5 06:31:17 EDT 2008
.ric is the index file for MpGuide 6.5. You get an equivalent xml index file
created by gdal (gdal notes web page) when you add your tiffs. the .tfw
files contain the extens for the tif files but if your tiffs are geotiffs
then these would already contain this extent info within its header. You can
view the xml index file by clicking on the Edit optiion within MG connection
page. make sure the coordinate system is the same as your map's coord
system. Also make sure that the extents within the coordinate system are
good enough to enclose all of your tifs.
regards,
W Khattak
jamesdudden wrote:
> ok, one more question for now then i will take all this information and
> discuss it with the person who creates the tifs.
> What are .ric and .tfw files for - i thought they contained the coordinate
> details - and can MGOS link to them?
> Regards
> James Dudden
> zspitzer wrote:
>> the first one is missing the co-ordinates.. you need to set that
>> value, rasters are fussier
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18828455.html
