[mapguide-users] How do i load raster in MGOS 2?
jamesdudden jamesdudden at blueyonder.co.uk
Tue Aug 5 11:45:48 EDT 2008
Frank - thank you again for all your continued support
You are right i had moved the file but not the .tfw - i moved it back and
then did a new print out and there is more data (as you can see below) so i
investigated and it seems the tif file is corrupt or something as i can't
open it in anything.
So back to my image guy for a new .tif and .tfw and then we'll see where
we're at.
Driver: GTiff/GeoTIFF
Files: C:\Program
Files\Autodesk\MapGuideStudio2009\SampleData\Raster\tif\Savills SSE
Tq12sw.tif
Size is 7874, 7874
Coordinate System is `'
Origin = (510000.000000500000000,124999.999999500000000)
Pixel Size = (0.889001000000000,-0.889001000000000)
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  510000.000,  125000.000)
Lower Left  (  510000.000,  118000.006)
Upper Right (  516999.994,  125000.000)
Lower Right (  516999.994,  118000.006)
Center      (  513499.997,  121500.003)
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
    NBITS=1
  Color Table (RGB with 2 entries)
    0: 255,255,255,255
    1: 0,0,0,255
Regrds
James Dudden
Frank Warmerdam-2 wrote:
> Actually, from the email I see that you copied Savills.tif into the
> FWTools2.2.1 directory before running gdalinfo on it.  Did you also copy
> along any .tfw file to the same place?  The files need to be kept together
> to work properly.
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18833908.html
