[mapguide-users] fusion - default tool selected?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Aug 6 20:12:09 EDT 2008
Maybe someone could added this change to the templates permanently, so
that it will be in the next MGOS release?
Andrew
Nolte, Tim wrote:
> Andrew,
> You are correct. I actually saw this thread and decided to implement
> this myself and that function is where I placed the code and it works
> great!
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org on behalf of Andrew
> DeMerchant
> Sent: Wed 8/6/2008 7:06 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] fusion - default tool selected?
> I'm using Studio / Maestro to design this, so I'm not 100% sure where
> this would be getting called. Judging by the content of the index.html
> files in the templates folders, it looks to me like I just modify the
> "fusionInitialized" function....is that right? (I'd just try it right
> now, but I'm home!)
> Andrew
> Mike Adair wrote:
> > In your Fusion init method (i.e. a function registered to the
> > FUSION_INITIALIZED event), you can activate a widget like so:
> >    var mapWidget = Fusion.getMapById('mainMap');
> >    //enable pan widget
> >    mapWidget.activateWidget(Fusion.getWidgetsByType('Pan')[0]);
> > getWidgetsByType returns an array of widgets so the [0] in the above
> > statement just selects the first instance of the Pan widget.
> > Mike
> > Andrew DeMerchant wrote:
> >> Is there a way to make the Select tool selected by default in fusion?
> >> What I mean is, if I load a Fusion map there is no tool selected. So
> >> the user can click and click all they want, but nothing will ever
> >> happen until they pick the Select tool (or some other tool). In AJAX
> >> and DWF, the Select tool is selected by default - so as soon as the
> >> map loads, you can start clicking on the map to see stuff....Is there
> >> an easy way to do that in Fusion? Is it a matter of editing the
> >> templates somehow?
> >> Andrew
> >>     *Andrew DeMerchant*
> >> *Computer Technologist*
> >> ph.1-877-2GEMTEC x.163
> >> fax 506-453-9470
> >> /GEMTEC Limited <http://www.gemtec.ca>
> >> /191 Doak Road
> >> Fredericton, NB, Canada
> >> E3C 2E6
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
