[mapguide-users] fusion - default tool selected?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Aug 7 09:55:48 EDT 2008
Would there be a way to do this more generically (ie without having to
hard-code the main name)? Like, why does this work:
var mapWidget = Fusion.getWidgetById('Pan');
mapWidget.activateWidget(Fusion.getWidgetsByType('Pan')[0]);
The link to the fusion api on the trac site doesn't exist - so I don't
really see a place to check this stuff....
Andrew
Mike Adair wrote:
> In your Fusion init method (i.e. a function registered to the
> FUSION_INITIALIZED event), you can activate a widget like so:
> var mapWidget = Fusion.getMapById('mainMap');
> //enable pan widget
> getWidgetsByType returns an array of widgets so the [0] in the above
> statement just selects the first instance of the Pan widget.
> Mike
> Andrew DeMerchant wrote:
>> Is there a way to make the Select tool selected by default in fusion?
>> What I mean is, if I load a Fusion map there is no tool selected. So
>> the user can click and click all they want, but nothing will ever
>> happen until they pick the Select tool (or some other tool). In AJAX
>> and DWF, the Select tool is selected by default - so as soon as the
>> map loads, you can start clicking on the map to see stuff....Is there
>> an easy way to do that in Fusion? Is it a matter of editing the
>> templates somehow?
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
