[mapguide-users] trouble replicating interstate symbol definition
Martin Morrison martin.morrison at edsi.com
Thu Aug 7 11:21:33 EDT 2008
I encode the image directly in the XML.  Try substituting your symbol
for this one.
Thanks,
Martin
  <SimpleSymbol>
                <SimpleSymbolDefinition>
                  <Name>Shield</Name>
                  <Graphics>
    <Image>
      <Content>
iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1MuSAAAAALHRFWHRDcmVhdGlvbiBUaW1l
AEZy
aSAzMCBNYXkgMjAwOCAxMzo0OTo0NyAtMDUwMBH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAA
CXBI
WXMAAAsSAAALEgHS3X78AAAABGdBTUEAALGPC/xhBQAAACpQTFRFxt7G///3////pc73hITG
AAD/
Y2PG56WE/wAA52NC56XG50JC54SE52OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSURBVHja1dfb
koMg
DAZgf0KVtd33f91FTgUUAZObzU2diX6TgFRYFhdY7qOTR5GHUgCat6KXt+lSO+J4DjUUcp00
Cuz7
zEUUZuOWAjN74wlg/zU2tgbo8nmr9to9YD47qvBSjO2c94m90GCY8S3OXn0kNXZp5p04pXa2
loqz
v5uI5jiJRo35EdViqyKNRg1h/bHDtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCK
msjA
+UmQGjiE/16RVrVKmkCrsVGZ4pA+qALFkco1bnEoNyK8aaVqkwTO0tfn/RtDOz4t1ebyea/V
1pLH
0QljcFfYgodv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213R
L2zU
0zRUWMYpaoEUTkRjWPKuQJq2Mq8A10DNWt6LR0/Sx1BROvTNWyWYnR8fUgmEjJSLY9If47Y6
+jho
AQAAAAAASUVORK5CYII=
      </Content>
      <SizeX>8.0</SizeX>
      <SizeY>8.0</SizeY>
      <SizeScalable>True</SizeScalable>
      <Angle>0.0</Angle>
      <PositionX>0.0</PositionX>
      <PositionY>0.0</PositionY>
    </Image>
                                <Text>
<ResizeControl>'AddToResizeBox'</ResizeControl>
                                  <Content>%ROADNAME%</Content>
                                  <FontName>'Arial'</FontName>
                                  <Height>4</Height>
                                  <PositionX>0</PositionX>
                                  <PositionY>0</PositionY>
<HorizontalAlignment>'Center'</HorizontalAlignment>
<VerticalAlignment>'Halfline'</VerticalAlignment>
                                  <TextColor>FFFFFFFF</TextColor>
                                </Text>
                  </Graphics>
                  <ResizeBox>
                                <SizeX>6</SizeX>
                                <SizeY>6</SizeY>
                                <GrowControl>'GrowInX'</GrowControl>
                  </ResizeBox>
                  <LineUsage>
                                <AngleControl>'FromAngle'</AngleControl>
<VertexControl>'OverlapNoWrap'</VertexControl>
                                <Angle>0</Angle>
                                <StartOffset>0</StartOffset>
                                <EndOffset>0</EndOffset>
                                <Repeat>50</Repeat>
<VertexAngleLimit>180.0</VertexAngleLimit>
                  </LineUsage>
                  <ParameterDefinition>
                                <Parameter>
                                 <Identifier>ROADNAME</Identifier>
                                 <DefaultValue>5</DefaultValue>
                                 <DisplayName>ROADNAME</DisplayName>
                                 <Description>ROADNAME</Description>
                                 <DataType>Integer</DataType>
                                </Parameter>
                  </ParameterDefinition>
                </SimpleSymbolDefinition>
                <RenderingPass>2</RenderingPass>
  </SimpleSymbol>
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan
Manafi
Sent: Thursday, August 07, 2008 11:18 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] trouble replicating interstate symbol
definition
Jonathan Manafi wrote:
As far as I know, yes. So far, I have had all other composite symbols I
have created work for me. But this is the first one where I am trying to
include an image in the symbol, and I have apparently not figured out
how that is supposed to work.
Martin Morrison wrote:
Just wondering aloud here...are composite symbol definitions supported
in 1.2?  I know I have them working in 2.x.
Thanks,
Martin
-----Original Message-----
Manafi
Sent: Thursday, August 07, 2008 11:07 AM
definition
Has anyone else tried to implement interstate signs?
Thanks.
J Manafi wrote:
	I have been reading RFC 14 to understand composite features, and
so
far, it
	has gone well. However, up until now, I haven't used any images
in the
	symbol definition. I tried replicating the interstate using a
highway
badge,
	stored as a .png file in a symbol library, and I am having no
luck. I
simply
	copied and pasted the xml for the symbol, changing my library
paths,
and I
	only get the text to show up. Here's what I did:
	-downloaded image of highway badges
	-cropped image to one I needed
	-uploaded to symbol library through studio 2008
	-copy/pasted code for symbol definition and changed path
	-tried creating layer using pointing to symbol
	I first tried only the highway badge. But after that, I tried a
	CompoundSymbolDefinition that included 2 paths to draw the road
in
yellow
	and black. Everything but the badge showed up. I thought maybe
editing
the
	image caused some issues, but I was able to use the image as a
W2D
stream in
	a PointSymbolization2D layer.
	Can anyone help me determine what I have done wrong here? My
setup is
MGOS
	1.2, win XP, apache + php.
	I am including the files that I used to go through this process.
	http://www.nabble.com/file/p18820020/Symbol%2BDef.txt Symbol
Def.txt
	http://www.nabble.com/file/p18820020/Layer%2BDef.txt Layer
Def.txt
	http://www.nabble.com/file/p18820020/interstate.png
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080807/21699b5d/attachment.html
