[mapguide-users] trouble replicating interstate symbol definition
Jonathan Manafi jonathan.manafi at cctechnol.com
Thu Aug 7 11:40:04 EDT 2008
I have been using Studio to create my symbol definitions, and in its
current form, your symbol gave an error. However, removing the
<SimpleSymbol> and <RenderingPass> tags allowed me to save the symbol
definition. Yet, I got the same result with this--nothing showed up on
screen when I created the line. So, I tried substituting this into a
<CompoundSymbolDefinition> along with some lines drawn representing a
road, and only the road lines showed up on screen.
I have tried encoding my image as well, using a site I found that
converts a file to base64, and that hasn't worked for me either.
One question though: when I encoded my image, the base64 string was a
lot longer, probably 10x or more as long. Does that seem normal? The
image itself is under 6k.
Thanks for your help.
Martin Morrison wrote:
> I encode the image directly in the XML.  Try substituting your symbol
> for this one.
> Thanks,
> Martin
>   <SimpleSymbol>
>                 <SimpleSymbolDefinition>
>                   <Name>Shield</Name>
>                   <Graphics>
>     <Image>
>       <Content>
> iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1MuSAAAAALHRFWHRDcmVhdGlvbiBUaW1lAEZy
> aSAzMCBNYXkgMjAwOCAxMzo0OTo0NyAtMDUwMBH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAACXBI
> WXMAAAsSAAALEgHS3X78AAAABGdBTUEAALGPC/xhBQAAACpQTFRFxt7G///3////pc73hITGAAD/
> Y2PG56WE/wAA52NC56XG50JC54SE52OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSURBVHja1dfbkoMg
> DAZgf0KVtd33f91FTgUUAZObzU2diX6TgFRYFhdY7qOTR5GHUgCat6KXt+lSO+J4DjUUcp00Cuz7
> zEUUZuOWAjN74wlg/zU2tgbo8nmr9to9YD47qvBSjO2c94m90GCY8S3OXn0kNXZp5p04pXa2loqz
> v5uI5jiJRo35EdViqyKNRg1h/bHDtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCKmsjA
> +UmQGjiE/16RVrVKmkCrsVGZ4pA+qALFkco1bnEoNyK8aaVqkwTO0tfn/RtDOz4t1ebyea/V1pLH
> 0QljcFfYgodv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213RL2zU
> 0zRUWMYpaoEUTkRjWPKuQJq2Mq8A10DNWt6LR0/Sx1BROvTNWyWYnR8fUgmEjJSLY9If47Y6+jho
> AQAAAAAASUVORK5CYII=
>       </Content>
>       <SizeX>8.0</SizeX>
>       <SizeY>8.0</SizeY>
>       <SizeScalable>True</SizeScalable>
>       <Angle>0.0</Angle>
>       <PositionX>0.0</PositionX>
>       <PositionY>0.0</PositionY>
>     </Image>
>                                 <Text>
> <ResizeControl>'AddToResizeBox'</ResizeControl>
>                                   <Content>%ROADNAME%</Content>
>                                   <FontName>'Arial'</FontName>
>                                   <Height>4</Height>
>                                   <PositionX>0</PositionX>
>                                   <PositionY>0</PositionY>
> <HorizontalAlignment>'Center'</HorizontalAlignment>
> <VerticalAlignment>'Halfline'</VerticalAlignment>
>                                   <TextColor>FFFFFFFF</TextColor>
>                                 </Text>
>                   </Graphics>
>                   <ResizeBox>
>                                 <SizeX>6</SizeX>
>                                 <SizeY>6</SizeY>
>                                 <GrowControl>'GrowInX'</GrowControl>
>                   </ResizeBox>
>                   <LineUsage>
>                                 <AngleControl>'FromAngle'</AngleControl>
> <VertexControl>'OverlapNoWrap'</VertexControl>
>                                 <Angle>0</Angle>
>                                 <StartOffset>0</StartOffset>
>                                 <EndOffset>0</EndOffset>
>                                 <Repeat>50</Repeat>
>                                 <VertexAngleLimit>180.0</VertexAngleLimit>
>                   </LineUsage>
>                   <ParameterDefinition>
>                                 <Parameter>
>                                  <Identifier>ROADNAME</Identifier>
>                                  <DefaultValue>5</DefaultValue>
>                                  <DisplayName>ROADNAME</DisplayName>
>                                  <Description>ROADNAME</Description>
>                                  <DataType>Integer</DataType>
>                                 </Parameter>
>                   </ParameterDefinition>
>                 </SimpleSymbolDefinition>
>                 <RenderingPass>2</RenderingPass>
>   </SimpleSymbol>
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Jonathan Manafi
> *Sent:* Thursday, August 07, 2008 11:18 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] trouble replicating interstate symbol
> definition
> Jonathan Manafi wrote:
> As far as I know, yes. So far, I have had all other composite symbols
> I have created work for me. But this is the first one where I am
> trying to include an image in the symbol, and I have apparently not
> figured out how that is supposed to work.
> Just wondering aloud here...are composite symbol definitions supported
> in 1.2?  I know I have them working in 2.x.
> Thanks,
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan
> Manafi
> Sent: Thursday, August 07, 2008 11:07 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] trouble replicating interstate symbol
> definition
> Has anyone else tried to implement interstate signs?
> Thanks.
> J Manafi wrote:
>     I have been reading RFC 14 to understand composite features, and so
> far, it
>     has gone well. However, up until now, I haven't used any images in the
>     symbol definition. I tried replicating the interstate using a highway
> badge,
>     stored as a .png file in a symbol library, and I am having no luck. I
> simply
>     copied and pasted the xml for the symbol, changing my library paths,
> and I
>     only get the text to show up. Here's what I did:
>     -downloaded image of highway badges
>     -cropped image to one I needed
>     -uploaded to symbol library through studio 2008
>     -copy/pasted code for symbol definition and changed path
>     -tried creating layer using pointing to symbol
>     I first tried only the highway badge. But after that, I tried a
>     CompoundSymbolDefinition that included 2 paths to draw the road in
> yellow
>     and black. Everything but the badge showed up. I thought maybe editing
> the
>     image caused some issues, but I was able to use the image as a W2D
> stream in
>     a PointSymbolization2D layer.
>     Can anyone help me determine what I have done wrong here? My setup is
> MGOS
>     1.2, win XP, apache + php.
>     I am including the files that I used to go through this process.
>     http://www.nabble.com/file/p18820020/Symbol%2BDef.txt Symbol Def.txt
>     http://www.nabble.com/file/p18820020/Layer%2BDef.txt Layer Def.txt
>     http://www.nabble.com/file/p18820020/interstate.png interstate.png
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080807/4144b016/attachment.html
