[mapguide-users] query in sheboygan is not working
oamram oamram at gmail.com
Thu Aug 7 21:59:08 EDT 2008
Hi tom,
Thank you very much for the help, i will change it as soon as i get to my
desktop.
as far as i understand from the instruction just replace  "GetTransform"
with "MgCoordinateSystemTransform".
Thanks very much, Omer.
Tom Fukushima wrote:
> The online version is running 1.2 and there were some breaking API changes
> with the coordinate system API in 2.0 (see
> http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes) so that's why the
> online version works, but yours doesn't.  You will probably need to change
> the PHP scripts so that "new MgCoordinateSystemTransform" is not used.
> BTW, to help you debug these PHP pages, you should turn the PHP error
> logging on in the php.ini file found in the WebServerExtensions/Php
> directory.  Search for the line that starts with display_errors (not "; -
> display_errors" because that's a comment line) and change it to
> display_errors = on.  You may have to restart your web server.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of oamram
> Sent: Thursday, August 07, 2008 5:12 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] query in sheboygan is not working
> Hi All,
> new to this, i installed mapguide 2 and it works great.
> however the query function does not work at all.
> any suggestion on how to solve it?
> i also download the redding package and the query does not work, how on
> the
> online version of the
> of the redding application the query function does work.
> much appriciated , Omer.
> http://www.nabble.com/query-in-sheboygan-is-not-working-tp18881736p18881736.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/query-in-sheboygan-is-not-working-tp18881736p18883809.html
