[mapguide-users] Does it matter where you install Mapguide?
nclayton nclayton at gmail.com
Tue Aug 12 10:51:34 EDT 2008
You can use the administration interface to change the location for your
repository folders. So I would suggest installing the server in the default
location to save a little headache then copy the repository folder the new
location and change the path inside the admin area.
jamesdudden wrote:
> Hi,
> The host where i am about to install suggests installing in a different
> folder so the repositries etc will get backed up - otherwise we will have
> to back up the whole program files folder.
> Any advice would be appreciated
> Regards
> James
View this message in context: http://www.nabble.com/Does-it-matter-where-you-install-Mapguide--tp18945808p18945875.html
