[mapguide-users] Does it matter where you install Mapguide?
Jason Birch Jason.Birch at nanaimo.ca
Tue Aug 12 12:47:56 EDT 2008
As mentioned, you can (and likely should) move your repository to a
location outside of the program files directory.
If you want to install MapGuide to an alternate location, Zac wrote up
the instructions on his blog:
http://tinyurl.com/668765
This method is not officially supported, but works in my experience.
Jason
-----Original Message-----
Subject: [mapguide-users] Does it matter where you install Mapguide?
The host where i am about to install suggests installing in a different
folder so the repositries etc will get backed up - otherwise we will
have to
back up the whole program files folder.
Any advice would be appreciated
