[mapguide-users] How to export a WebLayouts toolbox and menu
configuration
stoff
mail at effing.org
Sun Aug 17 10:24:18 EDT 2008
Dear Kenneth,
thanks a lot for your good explanation. It helped a lot... !
It is not documented anywhere, isn't it?
Best regards,
stoff
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you right click the WebLayout after it has been created, you can
> choose something like "Save to Xml...".
> This is the xml file.
> From Studio, you cannot restore the file, but you have 2 options:
> 1. Go to:
> http://localhost/mapguide/mapagent/index.html
> Click "Resource" (top-left) and "SetResource" (bottom-left)
> On the right, enter the full path of the target WebLayout, eg.:
> Library://myfolder/mylayout.WebLayout
> Browse the "Content" file, and select the xml file.
> Click "Submit".
> 2. Download Maestro:
> http://trac.osgeo.org/mapguide/wiki/maestro
> You have 2 options:
> a) Create a new WebLayout.
> Click "Edit Xml" (button on the top toolbar)
> Paste your new xml into the box.
> Click "OK"
> Click the "Save" icon (button on the top toolbar)
> b) Create a new WebLayout
> Save it.
> Right click it, and select "Load from Xml"
> Regards, Kenneth Skovhede, GEOGRAF A/S
> stoff skrev:
>> Hi,
>> where do I find the target XML File? Where can I place the a new modified
>> XML File to be reloaded by MapGuide Studio...?
>> Bes regards,
>> stoff
>>> then merge the toolbox/contextmenu/task sections from the source XML
>>> file
>>> into the target XML, then reload the modified XML file for the layout
>>> onto
>>> the target server.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-to-export-a-WebLayouts-toolbox-and-menu-configuration-tp18774434p19020270.html
