[mapguide-users] UnManagedData Slow
Zac Spitzer
zac.spitzer at gmail.com
Tue Aug 19 23:31:16 EDT 2008
It is still an issue, it occurs when using a single SDF which contains
multiple schemas as well
On Wed, Aug 20, 2008 at 6:15 AM, Rock Beans <rockbeans at gmail.com> wrote:
> Unmanaged is separate from pooling as pooling was a work around to
> speed things up when unmanaged was broke. Pooling works on managed and
> unmanaged data. Looking back it really did not help the issue at all.
> I have heard unmanaged shp (multiple within one folder) is still an
> issue though I have yet to prove that. I would also love confirmation
> that we can start dumping 20-40 shp files in one aliased folder to
> eliminate the need for load procedures and multiple feature sources.
> The Rock
> On Tue, Aug 19, 2008 at 11:20 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> Was this issue resolved? Are SDF and SHP safe to pool?
>> On Tue, Jul 10, 2007 at 2:43 AM, Bruce Dechant
>> <bruce.dechant at autodesk.com> wrote:
>>> SDF and SHP are excluded from pooling because of an update/reader issue
>>> within FDO that has not been addressed yet.
>>> If you notice some problems with update/readers then you should leave it
>>> as excluded. I believe this is planned to be fixed with the next release
>>> of FDO post MGOS 1.2.
>>> Thanks,
>>> Bruce
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nichols,
>>> David
>>> Sent: July 5, 2007 10:23 AM
>>> To: MapGuide Users Mail List
>>> Subject: RE: [mapguide-users] UnManagedData Slow
>>> That did it!! Thanks.
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
>>> Morsell
>>> Sent: Thursday, July 05, 2007 11:32 AM
>>> To: 'MapGuide Users Mail List'
>>> See this existing trac ticket on this topic:
>>> http://trac.osgeo.org/mapguide/ticket/175. If you enable pooling for
>>> SDF (I believe SDF by default is excluded from pooling in
>>> serverconfig.ini) you should see the same performance increase noted in
>>> the ticket. The development team is aware of these issues and have set
>>> the milestone for this to be fixed in release 1.3
>>> Andy Morsell, P.E.
>>> Spatial Integrators, Inc.
>>> http://www.SpatialGIS.com
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nicholda
>>> Sent: Thursday, July 05, 2007 5:58 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] UnManagedData Slow
>>> Hi all,
>>> I hope someone can point me in the right direction, I am using 1.2 and
>>> have re-mapped data to a location on disk. I am seeing a noticeable
>>> difference in response time between managed and unmanaged data. I
>>> re-mapped my feature source as shown below.
>>> Original
>>> <?xml version="1.0" encoding="utf-8"?>
>>> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>> <Provider>OSGeo.SDF</Provider>
>>> <Parameter>
>>> <Name>File</Name>
>>> <Value>>%MG_DATA_FILE_PATH%AsBuiltBldgs.sdf</Value>
>>> </Parameter>
>>> <Parameter>
>>> <Name>ReadOnly</Name>
>>> <Value>TRUE</Value>
>>> </Parameter>
>>> </FeatureSource>
>>> Modified
>>> <Parameter>
>>> <Name>File</Name>
>>> <Value>E:/FME_Data/mgos/AsBuiltBldgs.sdf</Value>
>>> </Parameter>
>>> <Parameter>
>>> <Value>FALSE</Value>
>>> </Parameter>
>>> </FeatureSource>
>>> After re-mapping I added the following alias to the serverconfig.ini
>>> file.
>>> [UnmanagedDataMappings]
>>> UnmanagedSdf = E:\FME_Data\mgos
>>> I then used the EnumerateUnmanagedData API to get the following. But I
>>> am not sure what to do next.
>>> <?xml version="1.0" encoding="UTF-8"?> <UnmanagedDataList
>>> xsi:noNamespaceSchemaLocation="UnmanagedDataList-1.0.0.xsd">
>>> <UnmanagedDataFile>
>>> <UnmanagedDataId>[UnmanagedSdf]AsBuiltBldgs.sdf</UnmanagedDataId>
>>> <CreatedDate>2007-06-28T13:00:40Z</CreatedDate>
>>> <ModifiedDate>2007-06-28T13:00:40Z</ModifiedDate>
>>> <Size>563200</Size>
>>> </UnmanagedDataFile>
>>> </UnmanagedDataList>
>>> Am I on the right track for improved performance/response time or am I
>>> completely off base. Any suggestions are welcomed.
>>> Thanks,
>>> David
>>> View this message in context:
>>> http://www.nabble.com/UnManagedData-Slow-tf4029540s16610.html#a11445964
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> This footnote confirms that this email message has been scanned by
>>> PineApp Mail-SeCure for the presence of malicious code, vandals &
>>> computer viruses.
>>> computer viruses.
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
Zac Spitzer -
+61 405 847 168
