[mapguide-users] Again question about Eastern european charset
& king.oracle
Simon Pelicon
simon at sl-king.com
Thu Aug 21 05:53:25 EDT 2008
I have tested this for (č,š,ž,đ) and i see them correctly.
My system settings are:
Windows Xp:
Standard And formats: Croatian
Language:Croatia
Language for non-unicode programs:Croatian
Web server:
IIS with PHP
Oracle 10gR2:
NLS_CHARACTERSET EE8MSWIN1250
If you enter this characters for example in feature Label as constant
expression do you see them correctly?
Simon
Dragan Podvezanec wrote:
> Hi all.
> I'm stuck with eastern european characters (č,š,ž,đ) and Oracle.
> I tried different NLS_LANG parameters on client (which is also the server),
> and always have some kind of errors. What is most strange to me is that
> FDO2FDO tool shows those characters without errors, and Mapguide OS doesn't
> show those characters (in MapFrame), although they use same provider. So,
> where does some charset conversion take place?
> Here is my setup:
> MGOS and Oracle on same machine, all regional settings and languages on
> croatian, database charset WIN1250 (I can't change this because of possible
> data loss). NLS_LANG parameter in registry is CROATIAN_CROATIA.EE8MSWIN1250
> FDO2FDO, Toad, and other dB tools: OK
> MGOS Viewer with king.Oracle provider: NOT ok, characters don't show or ?
> shows instead.
