[mapguide-users] Fusion + Oracle datasource problem
Paul Spencer pagameba at gmail.com
Thu Aug 21 12:51:37 EDT 2008
The problem in this particular case is that Fusion unnecessarily
enumerates the full schema of all the layers during initialization,
which for the Oracle provider in particular is very slow.  The ajax
viewer takes a different approach and defers schema enumeration until
it is necessary for some other reason.  We will be attempting to
implement the same approach in Fusion so that the startup time (to get
the app loaded and the first map drawn) is as short as possible.
Cheers
Paul
On 21-Aug-08, at 10:18 AM, Rock Beans wrote:
> To be honest how does the data source type affect one viewer over the
> other. I would think you would have the same issues in both. Most of
> the API calls are identical. I know there is a JavaScript compression
> fix that should be released soon with Fusion that should speed up
> initial loads. I am seeing Fusion being faster in every other area
> though personally.
> The Rock
> On Thu, Aug 21, 2008 at 1:59 AM, gingerbbm <stuart.jones at jacobs.com>
> wrote:
>> That all sounds really promising but unfortunately I'm working to an
>> aggressive deadline, and having paid money for the Autodesk
>> MapGuide product
>> I sort of assumed it would operate consistently regardless of my
>> choice of
>> viewer.
>> So what's the best way of keeping track of these new developments?
>> Do you
>> announce it here or somewhere else? I'd like to be involved if I
>> can be.
>> Cheers
>> Stuart
>> View this message in context: http://www.nabble.com/Fusion-%2B-Oracle-datasource-problem-tp17884373p19083167.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
