[mapguide-users] Scribble R2
Warren Medernach wmedernach at rand.com
Thu Aug 21 18:05:49 EDT 2008
Thanks Andy,
I had copied the DLLs, but it still wasn't working.
I ended up removing the app in IIS and re-creating it, and it is working
now.
Now onto see what it's going to take to get this running in Fusion...
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, August 21, 2008 3:26 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Scribble R2
It should work on MGE 2009 since the API changes were the same, but I
have not tried it.  Try replacing the dll files in the Bin directory
with the ones from MGE and see if that works.  If not, are you getting
any error messages?
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren
Medernach
Sent: Thursday, August 21, 2008 1:55 PM
To: MapGuide Users Mail List
I have setup the Scribble app as described, but can only get it to run
under an MGOS install?
Should I not be able to get this running on an install of MGE 2009?
Thanks
Warren Medernach
Morsell
Sent: Thursday, August 14, 2008 2:42 PM
I did not build the application, I just modified it to be compatible
with MGOS 2.0 and made some other tweaks.  It was originally created by
Dennis Jonio for MGOS 1.2.  In my particular case, a client is looking
for a .NET markup tool so I was looking at Dennis' scribble application
as a good starting point since the GT redlining app is PHP and nobody
has translated it to .NET yet.  This client uses AJAX layouts or I would
probably look more closely at a Fusion / OpenLayers solution.
Personally, I prefer Fusion and it is my layout of choice, but it's not
always my decision to make.
Hopefully people will start to create new Fusion widgets and contribute
those back to the community as well.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Thursday, August 14, 2008 1:07 PM
Subject: Re: [mapguide-users] Scribble R2
On more of a personal level is there a reason why you didn't make this
with Fusion in mind. I have bounced the idea of using the Flexible or
Standard layouts quite a bit and the one thing that gets me is will
Fusion become standard as far as development and support. Any thoughts
on your preferences?
On Thu, Aug 14, 2008 at 2:25 PM, Andy Morsell <amorsell at spatialgis.com>
wrote:
I have not tried to integrate it into a Fusion layout, so I don't know
for sure what it would take.  I can guarantee that much will be broken
since it references the AJAX frameset objects.
Andy
Sent: Thursday, August 14, 2008 12:11 PM
Is it easy to use with Fusion layouts as well?
On Thu, Aug 14, 2008 at 11:57 AM, Andy Morsell <amorsell at spatialgis.com>
wrote:
Hi all,
I just wanted everyone to know that I have modified the Scribble
community code sample that has been available on the wiki for some time
to be compatible with MapGuide Open Source 2.0.  I have also made some
changes to the application that allow it to be dropped into any generic
task pane in any AJAX web layout.  I have also bundled all needed dll's
and have created a new zip file of the entire package.  Please see the
existing Scribble page for more information:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
I hope this helps others.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080821/e46a9c9e/attachment.html
