[mapguide-users] Scribble R2
Andy Morsell
amorsell at spatialgis.com
Thu Aug 21 18:13:41 EDT 2008
Sounds like it was probably a .NET GAC problem then if it was first compiled
with the old dll's.
If you do get it working on Fusion, please consider contributing the changes
back to the group.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren
Medernach
Sent: Thursday, August 21, 2008 3:06 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Scribble R2
Thanks Andy,
I had copied the DLLs, but it still wasn't working.
I ended up removing the app in IIS and re-creating it, and it is working
now.
Now onto see what it's going to take to get this running in Fusion. ;-)
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Thursday, August 21, 2008 3:26 PM
To: 'MapGuide Users Mail List'
It should work on MGE 2009 since the API changes were the same, but I have
not tried it. Try replacing the dll files in the Bin directory with the
ones from MGE and see if that works. If not, are you getting any error
messages?
Andy
Medernach
Sent: Thursday, August 21, 2008 1:55 PM
I have setup the Scribble app as described, but can only get it to run under
an MGOS install?
Should I not be able to get this running on an install of MGE 2009?
Thanks
Warren Medernach
Sent: Thursday, August 14, 2008 2:42 PM
I did not build the application, I just modified it to be compatible with
MGOS 2.0 and made some other tweaks. It was originally created by Dennis
Jonio for MGOS 1.2. In my particular case, a client is looking for a .NET
markup tool so I was looking at Dennis' scribble application as a good
starting point since the GT redlining app is PHP and nobody has translated
it to .NET yet. This client uses AJAX layouts or I would probably look more
closely at a Fusion / OpenLayers solution. Personally, I prefer Fusion and
it is my layout of choice, but it's not always my decision to make.
Hopefully people will start to create new Fusion widgets and contribute
those back to the community as well.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Thursday, August 14, 2008 1:07 PM
Subject: Re: [mapguide-users] Scribble R2
On more of a personal level is there a reason why you didn't make this with
Fusion in mind. I have bounced the idea of using the Flexible or Standard
layouts quite a bit and the one thing that gets me is will Fusion become
standard as far as development and support. Any thoughts on your
preferences?
On Thu, Aug 14, 2008 at 2:25 PM, Andy Morsell <amorsell at spatialgis.com>
wrote:
I have not tried to integrate it into a Fusion layout, so I don't know for
sure what it would take. I can guarantee that much will be broken since it
references the AJAX frameset objects.
Andy
Sent: Thursday, August 14, 2008 12:11 PM
Is it easy to use with Fusion layouts as well?
On Thu, Aug 14, 2008 at 11:57 AM, Andy Morsell <amorsell at spatialgis.com>
wrote:
Hi all,
I just wanted everyone to know that I have modified the Scribble community
code sample that has been available on the wiki for some time to be
compatible with MapGuide Open Source 2.0. I have also made some changes to
the application that allow it to be dropped into any generic task pane in
any AJAX web layout. I have also bundled all needed dll's and have created
a new zip file of the entire package. Please see the existing Scribble page
for more information:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
I hope this helps others.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080821/b37e443e/attachment.html
