[mapguide-users] Fusion - how to set min zoom level?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Fri Aug 22 14:17:36 EDT 2008
That seemed promising, but then I noticed that I've already updated to
the version with that fix via svn - still doesn't work.
Andrew
Mike Adair wrote:
> I just fixed a bug that sounds similar to that:
> http://trac.osgeo.org/fusion/ticket/108. The initial view was
> overriding the max extent returned by MapGuide. This is on the trunk
> version (soon to be in a 1.1 version)
> Mike
> Andrew DeMerchant wrote:
>> I don't have defined scales for my map. I have an initial view
>> location - In my case, AJAX most certainly does _not_ act like
>> Fusion. In AJAX, my map loads at 1:147716.....I can use the zoom
>> slider to zoom out to 1:4947533 (plenty far!). In Fusion, it loads at
>> 1:146319, but like I say, the zoom slider is all the way at the
>> bottom...I can't zoom out anymore. I can't even type in a new scale
>> manually...
>> Andrew
>> Maksim Sestic wrote:
>>> Andrew,
>>> AJAX acts in the same way if you have fixed set of scales defined
>>> for a map.
>>> Regards,
>>> Maksim Sestic
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>>> DeMerchant
>>> Sent: Friday, August 22, 2008 17:57
>>> To: MapGuide Users Mail List
>>> Subject: Re: [mapguide-users] Fusion - how to set min zoom level?
>>> Thanks - but I know how to set my initial view. I just want to be
>>> able to
>>> zoom out more, beyond that initial view. Right now, in Fusion (not
>>> in AJAX
>>> or DWF) I can't zoom out past my initial view.
>>> Andrew
>>> Rodolfo Moreno wrote:
>>>> I suposse that you are using studio 2009, well first you must
>>>> define an extent greater that your layers.
>>>> These values are accordign to your preference. It depends that how
>>>> many you want to zoom out.
>>>> Next you have that setting the map widget located in your flexible
>>>> layout.
>>>> Choose the radio button option "use custom view" and place the
>>>> scale and the center coordinates of you preference. These values
>>>> will determine the initial zoom.
>>>> Regards
>>>>> In my Fusion maps, I've just noticed that I can't zoom out beyond
>>>>> my initial map view. The zoom slider starts out at the bottom -
>>>>> this happens on all of my Fusion layouts. How do I set a different
>>>>> zoom out max limit (using Studio / Maestro)?
>>>>> Andrew
>>>>> *Andrew DeMerchant*
>>>>> *Computer Technologist*
>>>>> ph.1-877-2GEMTEC x.163
>>>>> fax 506-453-9470
>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>> /191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>> E3C 2E6
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Rodolfo Moreno
>>>> CivilEng
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature
>>> database 2888 (20080220) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
>>> signature
>>> http://www.eset.com
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
