[mapguide-users] Fusion - how to set min zoom level?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Aug 25 08:57:12 EDT 2008
Anyone got an answer for this? I have a fusion layout I'd like to roll
out, but can't until I get this resolved....
Andrew
Andrew DeMerchant wrote:
> That seemed promising, but then I noticed that I've already updated to
> the version with that fix via svn - still doesn't work.
> Andrew
> Mike Adair wrote:
>> I just fixed a bug that sounds similar to that:
>> http://trac.osgeo.org/fusion/ticket/108.  The initial view was
>> overriding the max extent returned by MapGuide.  This is on the trunk
>> version (soon to be in a 1.1 version)
>> Mike
>>> I don't have defined scales for my map. I have an initial view
>>> location - In my case, AJAX most certainly does _not_ act like
>>> Fusion. In AJAX, my map loads at 1:147716.....I can use the zoom
>>> slider to zoom out to 1:4947533 (plenty far!). In Fusion, it loads
>>> at 1:146319, but like I say, the zoom slider is all the way at the
>>> bottom...I can't zoom out anymore. I can't even type in a new scale
>>> manually...
>>> Andrew
>>> Maksim Sestic wrote:
>>>> Andrew,
>>>> AJAX acts in the same way if you have fixed set of scales defined
>>>> for a map.
>>>> Regards,
>>>> Maksim Sestic
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>>>> DeMerchant
>>>> Sent: Friday, August 22, 2008 17:57
>>>> To: MapGuide Users Mail List
>>>> Subject: Re: [mapguide-users] Fusion - how to set min zoom level?
>>>> Thanks - but I know how to set my initial view. I just want to be
>>>> able to
>>>> zoom out more, beyond that initial view. Right now, in Fusion (not
>>>> in AJAX
>>>> or DWF) I can't zoom out past my initial view.
>>>> Andrew
>>>> Rodolfo Moreno wrote:
>>>>> I suposse that you are using studio 2009, well first you must
>>>>> define an extent greater that your layers.
>>>>> These values are accordign to your preference. It depends that how
>>>>> many you want to zoom out.
>>>>> Next you have that setting the map widget located in your flexible
>>>>> layout.
>>>>> Choose the radio button option "use custom view" and place the
>>>>> scale and the center coordinates of you preference. These values
>>>>> will determine the initial zoom.
>>>>> Regards
>>>>>> In my Fusion maps, I've just noticed that I can't zoom out beyond
>>>>>> my initial map view. The zoom slider starts out at the bottom -
>>>>>> this happens on all of my Fusion layouts. How do I set a
>>>>>> different zoom out max limit (using Studio / Maestro)?
>>>>>> Andrew
>>>>>>     *Andrew DeMerchant*
>>>>>> *Computer Technologist*
>>>>>> ph.1-877-2GEMTEC x.163
>>>>>> fax 506-453-9470
>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>> /191 Doak Road
>>>>>> Fredericton, NB, Canada
>>>>>> E3C 2E6
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Rodolfo Moreno
>>>>> CivilEng
>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>> signature
>>>> database 2888 (20080220) __________
>>>> The message was checked by ESET NOD32 Antivirus.
>>>> http://www.eset.com
>>>> signature
>>>> http://www.eset.com
>>>     *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
