[mapguide-users] MGE2009 crashing
Zac Spitzer zac.spitzer at gmail.com
Thu Aug 28 11:39:30 EDT 2008
server is down it's the  /. effect
I am seeing this on XP/2003 with Apache and php / java as well. I think the
problem
lies in the mgserver side rather than anything in the webtier.
2.0.1 is still not stable enough, using tiled maps helped a lot, but it's
still a gamble.
I ended up developing a workaround which involves bypassing the MapGuide
server
altogether for tiled maps, using openlayers and a static copy of a fully
seeded tile
cache.
here's a demo, that's just plain old apache
http://ennoble.dreamhosters.com/maps/tm-kl/
z
On Fri, Aug 29, 2008 at 1:05 AM, BradM <masonb at dfo-mpo.gc.ca> wrote:
> We are using Apache.  The watershed atlas and its tool tips seem to be
> causing the server to choke:
> http://204.244.79.12/mapguide2009/SHIM/Shim.php
> Andy Morsell wrote:
> > That's very similar to the thread I started yesterday regarding crashing
> > problems I'm having with MGOS 2.0.1.  I am seeing the same error
> messages
> > in
> > the log files.  Are you using Windows Server / IIS / .NET?
> > Andy Morsell, P.E.
> > Spatial Integrators, Inc.
> > www.SpatialGIS.com
> > -----Original Message-----
> > From: mapguide-users-bounces at lists.osgeo.org
> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
> > Sent: Thursday, August 28, 2008 7:53 AM
> > To: mapguide-users at lists.osgeo.org
> > Subject: [mapguide-users] MGE2009 crashing
> > Our server crashed again last night.   Is more ram a possible solution?
> We
> > did not have this problem with MGE2008
> > thanks
> > <2008-08-27T14:36:56>    Anonymous
> >  Error: Out of memory.
> >         bad allocation
> >  StackTrace:
> >   - MgRenderingServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\
> > rendering\RenderingServiceHandler.cpp
> >   - MgOpQueryFeatures.Execute line 125 file
> > rendering\OpQueryFeatures.cpp
> >   - MgServerRenderingService.QueryFeatures line 647 file
> > rendering\ServerRenderingService.cpp
> >   - MgServerRenderingService.RenderForSelection line 1252 file
> > Out of memory.
> > bad allocation
> > View this message in context:
> > http://www.nabble.com/MGE2009-crashing-tp19202309p19202309.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MGE2009-crashing-tp19202309p19202572.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080829/7dcc0c54/attachment.html
