[mapguide-users] MGE2009 crashing
BradM masonb at dfo-mpo.gc.ca
Thu Aug 28 12:03:34 EDT 2008
Your map is very nice Z.  Your solution is to bypass MGserver altogether?
That is not very encouraging as we have a license and the MGE2008 version
seemed to work fine.
zspitzer wrote:
> server is down it's the  /. effect
> I am seeing this on XP/2003 with Apache and php / java as well. I think
> the
> problem
> lies in the mgserver side rather than anything in the webtier.
> 2.0.1 is still not stable enough, using tiled maps helped a lot, but it's
> still a gamble.
> I ended up developing a workaround which involves bypassing the MapGuide
> server
> altogether for tiled maps, using openlayers and a static copy of a fully
> seeded tile
> cache.
> here's a demo, that's just plain old apache
> http://ennoble.dreamhosters.com/maps/tm-kl/
> z
> On Fri, Aug 29, 2008 at 1:05 AM, BradM <masonb at dfo-mpo.gc.ca> wrote:
>> We are using Apache.  The watershed atlas and its tool tips seem to be
>> causing the server to choke:
>> http://204.244.79.12/mapguide2009/SHIM/Shim.php
>> Andy Morsell wrote:
>> > That's very similar to the thread I started yesterday regarding
>> crashing
>> > problems I'm having with MGOS 2.0.1.  I am seeing the same error
>> messages
>> > in
>> > the log files.  Are you using Windows Server / IIS / .NET?
>> > Andy Morsell, P.E.
>> > Spatial Integrators, Inc.
>> > www.SpatialGIS.com
>> > -----Original Message-----
>> > From: mapguide-users-bounces at lists.osgeo.org
>> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
>> > Sent: Thursday, August 28, 2008 7:53 AM
>> > To: mapguide-users at lists.osgeo.org
>> > Subject: [mapguide-users] MGE2009 crashing
>> > Our server crashed again last night.   Is more ram a possible solution?
>> We
>> > did not have this problem with MGE2008
>> > thanks
>> > <2008-08-27T14:36:56>    Anonymous
>> >  Error: Out of memory.
>> >         bad allocation
>> >  StackTrace:
>> >   - MgRenderingServiceHandler.ProcessOperation line 83 file
>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\
>> > rendering\RenderingServiceHandler.cpp
>> >   - MgOpQueryFeatures.Execute line 125 file
>> > rendering\OpQueryFeatures.cpp
>> >   - MgServerRenderingService.QueryFeatures line 647 file
>> > rendering\ServerRenderingService.cpp
>> >   - MgServerRenderingService.RenderForSelection line 1252 file
>> > Out of memory.
>> > bad allocation
>> > View this message in context:
>> > http://www.nabble.com/MGE2009-crashing-tp19202309p19202309.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/MGE2009-crashing-tp19202309p19202572.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/MGE2009-crashing-tp19202309p19203701.html
