[mapguide-users] How to Load Runtime map in mapviewerajax
padmini godavarthi godavarthi.padmini at gmail.com
Mon Dec 1 04:03:38 EST 2008
Hi thanks for u r reply.
But i dont want to give path for the map definition like
      layout.Map.ResourceId = "Library://mymap.MapDefinition";
i want to create it dynamically in the code .After creating weblayout how to
call it in the ajaxviewer sample application.
If u know this plz help me
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you want to create a WebLayout using the MaestroAPI, simpy do:
>             MaestroAPI.ServerConnectionI con; //You need this from the
> code in the example
>             MaestroAPI.WebLayout layout = new MaestroAPI.WebLayout();
>             layout.Map = new MaestroAPI.MapType();
>             con.SaveResourceAs(layout, "Library://mylayout.WebLayout");
> You might also want to add some buttons and set other options.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks for u r reply.
>> Actually i have created one mgp in mapguide maestro.
>> so  i placed it in  the ajaxviewer sample application as
>> weblayout="Library://Layout/maplayout.weblayout.
>> It works fine
>> Now i want to create it by coding using (Maestroapi.dll) dynamically  so
>> i
>> saw a link
>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
>> but i didnt get the code
>> So plz tell me the procedure sothat i will proceed further development
>> Regards,
>> Padmini
>> Maksim Sestic wrote:
>>> Then check the last few lines of this example:
>>> er
>>> ...but I suggest you reading a bit about MeastroAPI in general:
>>> Regards,
>>> Maksim Sestic
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>> godavarthi
>>> Sent: Thursday, November 27, 2008 02:22
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: RE: [mapguide-users] How to Load Runtime map in mapviewerajax
>>> Hi,
>>> I followed the given url
>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>>> i got an session id for that. After getting it iam unable to get what to
>>> do
>>> with that?
>>> can u plz tell me the procedure.
>>> Regards,
>>> padmini
>>>> You might check this out first:
>>>> Map
>>>> I guess it does exactly what you need.
>>>> Regards,
>>>> Maksim Sestic
>>>> godavarthi
>>>> Sent: Wednesday, November 26, 2008 17:15
>>>> Subject: [mapguide-users] How to Load Runtime map in mapviewerajax
>>>>    Hi,
>>>> iam using Mapguide opensource 2.0 (with .net 2.0+IIS 5.1).
>>>> Now i want to load a runtime map  (using MaestroAPI.dll) in to
>>>> mapviewer ajax application (in .net)
>>>> Plz tell me the procedure  for
>>>> 1) How to load the runtime map?
>>>> 2) What are the steps i have to follow?
>>>> If anybody knows plz help me
>>>> Regards,
>>>> Padmini
>>>> View this message in context:
>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-tp20704
>>>> 038p20
>>>> 704038.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>> signature database 3643 (20081126) __________
>>>> The message was checked by ESET NOD32 Antivirus.
>>>> http://www.eset.com
>>>> http://www.eset.com
>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-tp20704038p20
>>> 712155.html
>>> signature
>>> database 3644 (20081126) __________
>>> http://www.eset.com
>>> signature
>>> http://www.eset.com
View this message in context: http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-tp20704038p20768314.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081201/a02a4a63/attachment.html
