[mapguide-users] Permanent changes in data
Stefan Dalakov
s.dalakov at mapware.net
Tue Dec 2 03:20:52 EST 2008
It is something stupid, but I cannot spot it...
Everything works if I omit the bold part of the code :
function MakeLine($name, $x0, $y0 , $x1, $y1)
$propertyCollection = new MgPropertyCollection();
* $cntr = (double) 11.0 ;
$idProperty = new MgDoubleProperty("ID",$cntr);
$propertyCollection->Add($idProperty);
* $owner = "Aaa" ;
$ownerProperty = new MgStringProperty("Owner", $owner);
$propertyCollection->Add($ownerProperty);
$nameProperty = new MgStringProperty("Purpose", $name);
$propertyCollection->Add($nameProperty);
$wktReaderWriter = new MgWktReaderWriter();
$agfReaderWriter = new MgAgfReaderWriter();
$agftext = "LINESTRING XY ($x0 $y0, $x1 $y1)" ;
$geometry = $wktReaderWriter->Read( $agftext);
$geometryByteReader = $agfReaderWriter->Write($geometry);
$geometryProperty = new MgGeometryProperty("Geometry",
$geometryByteReader);
$propertyCollection->Add($geometryProperty);
return $propertyCollection;
MG Studio says this property is Double
Stefan Dalakov
Kenneth Skovhede, GEOGRAF A/S wrote:
> You could be affected by this bug:
> http://trac.osgeo.org/mapguide/ticket/649
> Otherwise, try to post a section of the code,
> maybe someone will spot something obvious.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Stefan Dalakov skrev:
>> Hi all,
>> I am trying to add a feature (permanently) to a data source.
>> I am using MGOS 1.2 and tried Sheboygan samples, where this part is
>> not working, I have not explored the reason yet.
>> My idea is to digitize a feature ( a line ) and add it permanently to
>> an existing layer on the map.
>> I wrote some code, and everything seems OK, no errors, but at the
>> end I have no feature added.
>> Can someone help with a piece of code ?
>> Thanks in advance
>> Stefan Dalakov
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081202/3387ed8b/attachment.html
