[mapguide-users] Permanent changes in data
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Dec 2 03:57:36 EST 2008
Could it be that "ID" is the primary key, and if you insert two features
with ID 11,
it breaks? Or that the ID is auto-assigned, and thus not assignable from
MapGuide/FDO?
btw, things tend to work better with MapGuide if your primary key is an
integer.
Regards, Kenneth Skovhede, GEOGRAF A/S
Stefan Dalakov skrev:
> It is something stupid, but I cannot spot it...
> Everything works if I omit the bold part of the code :
> function MakeLine($name, $x0, $y0 , $x1, $y1)
> $propertyCollection = new MgPropertyCollection();
> * $cntr = (double) 11.0 ;
> $idProperty = new MgDoubleProperty("ID",$cntr);
> $propertyCollection->Add($idProperty);
> * $owner = "Aaa" ;
> $ownerProperty = new MgStringProperty("Owner", $owner);
> $propertyCollection->Add($ownerProperty);
> $nameProperty = new MgStringProperty("Purpose", $name);
> $propertyCollection->Add($nameProperty);
> $wktReaderWriter = new MgWktReaderWriter();
> $agfReaderWriter = new MgAgfReaderWriter();
> $agftext = "LINESTRING XY ($x0 $y0, $x1 $y1)" ;
> $geometry = $wktReaderWriter->Read( $agftext);
> $geometryByteReader = $agfReaderWriter->Write($geometry);
> $geometryProperty = new MgGeometryProperty("Geometry",
> $geometryByteReader);
> $propertyCollection->Add($geometryProperty);
> return $propertyCollection;
> MG Studio says this property is Double
> Stefan Dalakov
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You could be affected by this bug:
>> http://trac.osgeo.org/mapguide/ticket/649
>> Otherwise, try to post a section of the code,
>> maybe someone will spot something obvious.
>>> Hi all,
>>> I am trying to add a feature (permanently) to a data source.
>>> I am using MGOS 1.2 and tried Sheboygan samples, where this part is
>>> not working, I have not explored the reason yet.
>>> My idea is to digitize a feature ( a line ) and add it permanently
>>> to an existing layer on the map.
>>> I wrote some code, and everything seems OK, no errors, but at the
>>> end I have no feature added.
>>> Can someone help with a piece of code ?
>>> Thanks in advance
>>> Stefan Dalakov
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081202/04881337/attachment.html
