[mapguide-users] Runtime map problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Dec 2 06:08:57 EST 2008
Instead of re-posting the original question,
could you try to explain what parts of my previous reply
that are unclear or wrong?
http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20704038.html#a20769349
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi ,
> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1)
> Iam using dotnet viewer sample while running the application i observed that
> the layout path given in the application.
> as
> String webLayout =
> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
> it works but now i want to create this weblayout in run time (by code)
> using mapguide maestro api
> for this purpose i followed the link
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
> but i didnt get any out.
> can u plz tell me
> 1) how to create this weblayout in run time
> 2) How it will works
> If u know this plz tell me the procedure.
> Regards,
> Padmini.
