[mapguide-users] Runtime map problem
padmini godavarthi godavarthi.padmini at gmail.com
Tue Dec 2 06:36:38 EST 2008
Thanks for u r reply
actually i wrote the code as
    Dim host As New Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
        Dim conn As New HttpServerConnection(host, "Administrator", "admin",
"en", True)
        Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
ResourceTypes.MapDefinition)
        Dim mapId As String = res.ResourceId
with that i got the map resource id.
But actually to run the application the url in the browser must be like
http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout
1) How can i get this weblayout (like
Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout) programmetically
2) I want to redirect to the ajax viewer sample application through asp.net
(like given by u )
     Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId for
your WebLayout...&USERNAME=Anonymous&PASSWORD=");
3) Can u plz tell me the purpose of runtime map (actualli iam in configusing
state)
Kenneth Skovhede, GEOGRAF A/S wrote:
> Instead of re-posting the original question,
> could you try to explain what parts of my previous reply
> that are unclear or wrong?
> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20704038.html#a20769349
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>>  Hi ,
>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1)
>> Iam using dotnet viewer sample while running the application i observed
>> that
>> the layout path given in the application.
>> as
>> String webLayout =
>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>  it works but now i want to create this weblayout in run time (by code)
>> using mapguide maestro api
>> for this purpose i followed the link
>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>> but i didnt get any out.
>> can u plz tell me
>> 1) how to create this weblayout in run time
>> 2) How it will works
>> If u know this plz tell me the procedure.
>> Regards,
>> Padmini.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Runtime-map-problem-tp20789983p20790458.html
