[mapguide-users] Uploading Shapefile to Map for Immediate DisplayProblem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 3 03:53:59 EST 2008
The delete is easy with MaestroAPI:
con.DeleteResource(...resourceId...);
The MapGuideAPI has something similar.
The edit is tough.
If you are looking for a Web UI, try looking at WebStudio (bundled with
MapGuide).
If you are looking for a client side UI, try customizing Maestro.
Both projects are licensed under the LGPL license, and should thus be
usable from other projects.
If you have needs to customize Maestro for better use by your
application, you can create a feature request ticket,
and I'll try to make it happen. (Patches are always welcome).
What are the problems with the Refresh() call?
Have you tried FireBug for Firefox to examine the problem?
Regards, Kenneth Skovhede, GEOGRAF A/S
Greenhough, Jamie skrev:
> Hey Kevin, I checked out your site. I am working on very similar
> functionality. My users need to be able to ADD, DELETE, and EDIT
> (stylize) layers.
> I used the Maestro API to implement the ADD functionality. See one of my
> previous messages for the code snippet here:
> http://www.nabble.com/DWGLoadProcedure-td20016401.html
> I also made a layerdefinition factory to create the XML necessary for
> creating the .LayerDefintion.
> For the layer to show up immediately, after the save, you need to invoke
> the Refresh() method from the viewerFrame. I haven't had any luck
> calling this method from a ASP user control yet. :(
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kevin_t
> Sent: Tuesday, December 02, 2008 1:06 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Uploading Shapefile to Map for Immediate
> DisplayProblem
> I like to set it up so that people can upload shapefiles from their
> computer
> to my mapguide map and have it immediately add it as a layer to my map
> and
> show up on screen immediately.  Does anybody know how to implement this
> functionality?  Or know where to download one that works?
> I have inherited customization in PHP code that does this but it's not
> working and I am unable to fix it.
> The map is located at:
> http://204.244.79.12/mapguide2009/uploadshp/canada_frameset.php
> Under Tasks on the right > Upload Shapefile
> Any help or suggestions will be greatly appreciated.
