[mapguide-users] SV: Runtime map problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Dec 3 06:37:50 EST 2008
There is not much I can say to help you there.
It is very difficult to create LayerDefinitions and WebLayouts
programatically.
The problem with creating a LayerDefinition is the number of properties
you have to set.
Such properties include, scalerange, point styles, rules, fonts,
linewidth, colors, etc.
The WebLayout has all the buttons and menu items.
I would recommend you reconsider alternatives.
To create a new LayerDefinition, simply do:
Dim layerdefinition as new MaestroAPI.LayerDefinition()
You can use the same approach for any of the other items.
Then you can save it as you like, using con.SaveResourceAs(...).
There is no help anywhere, that explains what properties to set.
You can look in the Maestro code, or examine the Sheboygan
LayerDefinitions to see what happens.
A simple shortcut, would be to create a "template" from Maestro, and then
use that template when you start out. You can then modify the template,
and save it as a resource. To produce a "template", simply create a new
LayerDefinition
in Maestro, and then click the "Edit Xml". Copy-n-paste the Xml to a
file (say C:\template.xml).
To load a template as an object, you can use (C# code, can never
remember generics in VB):
MaestroAPI.LayerDefinition layerdefinition;
using(System.IO.FileStream fs = System.IO.File.OpenRead("C:\\template.xml"))
layerdefintion = con.DeserializeObject<MaestroAPI.LayerDefinition>(fs);
You can then modify the geometry column, featuresource pointer, columns,
filter, tooltip and other items, until it fits the newly uploaded
SHP file. As I said, it will be dificult, and there is no help avalible
for the task. Your primary tool is the error log:
C:\program files\mapguideopensource2.0\server\logs\error.log
Good luck.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks .its working fine now.
> To build a map, you must have all the components:
> 1. FeatureSource, references data
> 2. LayerDefinition, references a FeatureSource
> 3. MapDefinition, references multiple LayerDefinitions
> 4. WebLayout, references a MapDefinition
> All these items must be in a repository (either Library or Session)
> I know the procedure to create it in mapguide maestro.
> 1) Now my problem was i want to create ALL the above items
> programmetically (my input is only a shape file) byusing maestro dll.
> If u know this plz help me
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I wrote a follow up, with corrected code.
>> You are using the initial one, and you are missing a "?" mark in the
>> redirect URL.
>> Try to use the updated version, and beware of the question mark in the
>> Response.Redirect call.
>>> Hi,
>>> Thanks for u r reply.
>>> I tried this code but i got an error that
>>> Server Error in '/maestro' Application.
>>> HTTP Error 400 - Bad Request.
>>> Version Information: ASP.NET Development Server 8.0.0.0
>>> my code was
>>> Dim host As New
>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>> Dim conn As New HttpServerConnection(host, "Administrator",
>>> "admin",
>>> "en", True)
>>> 'You have to change the string below to point at a valid
>>> WebLayout
>>> Dim weblayout As WebLayout =
>>> conn.GetWebLayout("Library://Filebased
>>> data/Layout/layout.WebLayout")
>>> Dim mapdefinition As MapDefinition =
>>> conn.GetMapDefinition(weblayout.Map.ResourceId)
>>> weblayout.Map.InitialView = New MapViewType()
>>> weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
>>> weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
>>> weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
>>> Dim tempid As ResourceIdentifier = New
>>> ResourceIdentifier("layout",
>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
>>> Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
>>> Server.UrlEncode(tempid)
>>> joscsu wrote:
>>>> Or this:
>>>> System.Guid.NewGuid().ToString()
>>>> ----- Ursprungligt meddelande ----
>>>> Från: Maksim Sestic <max at geoinova.com>
>>>> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>>> Skickat: tisdag 2 december 2008 16:49:21
>>>> Ämne: RE: [mapguide-users] Runtime map problem
>>>> Try this:
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>>> godavarthi
>>>> Sent: Tuesday, December 02, 2008 15:35
>>>> To: mapguide-users at lists.osgeo.org
>>>> Subject: Re: [mapguide-users] Runtime map problem
>>>> Hi,
>>>> Thanku very much for ur help
>>>> i tried this code
>>>> but i got an error in the line
>>>> Dim tempid as ResourceIdentifier = new
>>>> ResourceIdentifier(Guid.NewGuid(),
>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
>>>> because of this Guid.NewGuid()
>>>> 1) Actually what is this?
>>>> 2) Which paramater we have to pass in this place instead of
>>>> Guid.NewGuid()
>>>> Regards,
>>>> Padmini
>>>>> I forgot to save the weblayout in the code below :(
>>>>> Updated version is:
>>>>> 'Setup connection
>>>>> Dim host As New
>>>>> Dim conn As New HttpServerConnection(host, "Administrator", "admin",
>>>>> "en", True)
>>>>> 'You have to change the string below to point at a valid WebLayout Dim
>>>>> weblayout as WebLayout =
>>>>> con.GetWebLayout("Library://mylayout.WebLayout")
>>>>> Dim mapdefinition as MapDefinition =
>>>>> con.GetMapDefinition(weblayout.Map.ResourceId)
>>>>> 'Modify the initial view of the weblayout weblayout.Map.InitialView =
>>>>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>>>>> 1:2000 weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX
>>>>> 'Obtain a unique session based id for the temporary weblayout (which
>>>>> is a copy of an existing WebLayout) Dim tempid as ResourceIdentifier =
>>>>> new ResourceIdentifier(Guid.NewGuid(),
>>>>> 'Save the layout, otherwise you can't reference it
>>>>> con.SaveResourceAs(weblayout, tempid)
>>>>> 'Open the viewer, and use the temporary layout, since the map only
>>>>> exists in the 'current session, we must use that session, and NOT
>>>>> supply username/password
>>>>> 'BEWARE: The session belongs to the Administrator account, so the user
>>>>> gets full access to MapGuide (delete, modify, etc.)
>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
>>>>> Server.UrlEncode(tempid) & "&SESSION=" &
>>>>> Server.UrlEncode(con.SessionID))
>>>>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>>>>> references multiple LayerDefinitions 4. WebLayout, references a
>>>>>> MapDefinition
>>>>>> All these items must be in a repository (either Library or Session),
>>>>>> otherwise they can't be referenced.
>>>>>> When you write that you want to "create a WebLayout programatically",
>>>>>> do you want to create ALL the above items, or do you have layers and
>>>>>> featuresources?
>>>>>> (1) If you want to generate a WebLayout ResourceID, you should use:
>>>>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>>>>> ResourceTypes.WebLayout)
>>>>>> If you want to read the name of an existing MapDefinition from
>>>>>> another layout, you must do:
>>>>>> Dim weblayout as WebLayout =
>>>>>> Dim res as String = webLayout.Map.ResourceId
>>>>>> (2) I don't understand the question.
>>>>>> (3) The MapDefinition is an Xml document. Inside, it references
>>>>>> layers, which references featuresources, as described above. It is
>>>>>> very slow to do this, so when you open a map in the browser, the xml
>>>>>> is transformed into a binary object. This object contains all the
>>>>>> info from the MapDefinition and some info from the layers and
>>>>>> featuresources.
>>>>>> You need to know this, because if you try to toggle layer visibility
>>>>>> in the MapDefinition, nothing happens. In short, the Runtime Map is a
>>>>>> binary object that you can manipulate using the MapGuide (and
>>>>>> Maestro)-API, and it only works for a displayed map.
>>>>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>>>>> was created from.
>>>>>> A short example of using an existing WebLayout:
>>>>>> Dim host As New
>>>>>> "en", True)
>>>>>> weblayout.Map.InitialView = new MapViewType()
>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim tempid
>>>>>> as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
>>>>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>>>>>> Hi,
>>>>>>> actually i wrote the code as
>>>>>>> Dim host As New
>>>>>>> "admin", "en", True)
>>>>>>> data/Maps/mapdata",
>>>>>>> ResourceTypes.MapDefinition)
>>>>>>> Dim mapId As String = res.ResourceId
>>>>>>> with that i got the map resource id.
>>>>>>> But actually to run the application the url in the browser must be
>>>>>>> like
>>>>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>>>>> 1) How can i get this weblayout (like
>>>>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>>>>> programmetically
>>>>>>> 2) I want to redirect to the ajax viewer sample application through
>>>>>>> asp.net (like given by u )
>>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>>>>> for
>>>>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>>>>> configusing
>>>>>>> state)
>>>>>>>> Instead of re-posting the original question, could you try to
>>>>>>>> explain what parts of my previous reply that are unclear or wrong?
>>>>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>>>>> 704038.html#a20769349
>>>>>>>>> Hi ,
>>>>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1) Iam
>>>>>>>>> using dotnet viewer sample while running the application i
>>>>>>>>> observed that the layout path given in the application.
>>>>>>>>> as
>>>>>>>>> String webLayout =
>>>>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>>>>> it works but now i want to create this weblayout in run time (by
>>>>>>>>> code)
>>>>>>>>> using mapguide maestro api
>>>>>>>>> for this purpose i followed the link
>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>>>>> timeMap
>>>>>>>>> but i didnt get any out.
>>>>>>>>> can u plz tell me
>>>>>>>>> 1) how to create this weblayout in run time
>>>>>>>>> 2) How it will works
>>>>>>>>> If u know this plz tell me the procedure.
>>>>>>>>> Regards,
>>>>>>>>> Padmini.
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context:
>>>> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>> signature
>>>> database 3658 (20081202) __________
>>>> The message was checked by ESET NOD32 Antivirus.
>>>> http://www.eset.com
>>>> __________________________________________________________
>>>> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
>>>> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081203/b85197f4/attachment.html
