[mapguide-users] SV: Runtime map problem
padmini godavarthi godavarthi.padmini at gmail.com
Wed Dec 3 07:01:10 EST 2008
Thank u very much for u r reply.
I will check it out .
My Doubt is that
1) If i create a package in mapguide maestro , connecing to the oracle how
can access the data using queries.
   suppose i create a feature  resource for a table data in oracle after
that i followed all the procedure and created a package successfully. If
user wants to query this table and wants to display only some of the
features on the map dynamically .How can i provide this?
If u know this plz help me
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> There is not much I can say to help you there.
> It is very difficult to create LayerDefinitions and WebLayouts
> programatically.
> The problem with creating a LayerDefinition is the number of properties
> you have to set.
> Such properties include, scalerange, point styles, rules, fonts,
> linewidth, colors, etc.
> The WebLayout has all the buttons and menu items.
> I would recommend you reconsider alternatives.
> To create a new LayerDefinition, simply do:
> Dim layerdefinition as new MaestroAPI.LayerDefinition()
> You can use the same approach for any of the other items.
> Then you can save it as you like, using con.SaveResourceAs(...).
> There is no help anywhere, that explains what properties to set.
> You can look in the Maestro code, or examine the Sheboygan
> LayerDefinitions to see what happens.
> A simple shortcut, would be to create a "template" from Maestro, and then
> use that template when you start out. You can then modify the template,
> and save it as a resource. To produce a "template", simply create a new
> LayerDefinition
> in Maestro, and then click the "Edit Xml". Copy-n-paste the Xml to a
> file (say C:\template.xml).
> To load a template as an object, you can use (C# code, can never
> remember generics in VB):
> MaestroAPI.LayerDefinition layerdefinition;
> using(System.IO.FileStream fs =
> System.IO.File.OpenRead("C:\\template.xml"))
>     layerdefintion =
> con.DeserializeObject<MaestroAPI.LayerDefinition>(fs);
> You can then modify the geometry column, featuresource pointer, columns,
> filter, tooltip and other items, until it fits the newly uploaded
> SHP file. As I said, it will be dificult, and there is no help avalible
> for the task. Your primary tool is the error log:
> C:\program files\mapguideopensource2.0\server\logs\error.log
> Good luck.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks .its working fine now.
>> To build a map, you must have all the components:
>> 1. FeatureSource, references data
>> 2. LayerDefinition, references a FeatureSource
>> 3. MapDefinition, references multiple LayerDefinitions
>> 4. WebLayout, references a MapDefinition
>> All these items must be in a repository (either Library or Session)
>> I know the procedure to create it in mapguide maestro.
>>    1) Now my problem was  i want to create   ALL the above items
>> programmetically (my input is only a shape file)  byusing maestro dll.
>> Regards,
>> Padmini.
>>> I wrote a follow up, with corrected code.
>>> You are using the initial one, and you are missing a "?" mark in the
>>> redirect URL.
>>> Try to use the updated version, and beware of the question mark in the
>>> Response.Redirect call.
>>>> Hi,
>>>> Thanks for u r reply.
>>>> I tried this code but i got an error that
>>>> Server Error in '/maestro' Application.
>>>> HTTP Error 400 - Bad Request.
>>>> Version Information: ASP.NET Development Server 8.0.0.0
>>>> my code was
>>>>     Dim host As New
>>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>>>         Dim conn As New HttpServerConnection(host, "Administrator",
>>>> "admin",
>>>> "en", True)
>>>>         'You have to change the string below to point at a valid
>>>> WebLayout
>>>>         Dim weblayout As WebLayout =
>>>> conn.GetWebLayout("Library://Filebased
>>>> data/Layout/layout.WebLayout")
>>>>         Dim mapdefinition As MapDefinition =
>>>> conn.GetMapDefinition(weblayout.Map.ResourceId)
>>>>         weblayout.Map.InitialView = New MapViewType()
>>>>         weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
>>>>         weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX
>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
>>>>         weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY
>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
>>>>         Dim tempid As ResourceIdentifier = New
>>>> ResourceIdentifier("layout",
>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
>>>>         Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
>>>> Server.UrlEncode(tempid)
>>>> joscsu wrote:
>>>>>  Or this:
>>>>> System.Guid.NewGuid().ToString()
>>>>> ----- Ursprungligt meddelande ----
>>>>> Från: Maksim Sestic <max at geoinova.com>
>>>>> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>>>> Skickat: tisdag 2 december 2008 16:49:21
>>>>> Ämne: RE: [mapguide-users] Runtime map problem
>>>>> Try this:
>>>>> -----Original Message-----
>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>>>> godavarthi
>>>>> Sent: Tuesday, December 02, 2008 15:35
>>>>> To: mapguide-users at lists.osgeo.org
>>>>> Subject: Re: [mapguide-users] Runtime map problem
>>>>> Hi,
>>>>> Thanku very much for ur help
>>>>> i tried this code
>>>>> but i got an error in the line
>>>>> Dim tempid as ResourceIdentifier = new
>>>>> ResourceIdentifier(Guid.NewGuid(),
>>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
>>>>> because of this Guid.NewGuid()
>>>>> 1) Actually what is this?
>>>>> 2) Which paramater we have to pass in this place instead of
>>>>> Guid.NewGuid()
>>>>> Regards,
>>>>> Padmini
>>>>>> I forgot to save the weblayout in the code below :(
>>>>>> Updated version is:
>>>>>> 'Setup connection
>>>>>> Dim host As New
>>>>>> Dim conn As New HttpServerConnection(host, "Administrator", "admin",
>>>>>> "en", True)
>>>>>> 'You have to change the string below to point at a valid WebLayout
>>>>>> Dim
>>>>>> weblayout as WebLayout =
>>>>>> con.GetWebLayout("Library://mylayout.WebLayout")
>>>>>> Dim mapdefinition as MapDefinition =
>>>>>> con.GetMapDefinition(weblayout.Map.ResourceId)
>>>>>> 'Modify the initial view of the weblayout weblayout.Map.InitialView =
>>>>>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>>>>>> 1:2000 weblayout.Map.InitialView.CenterX =
>>>>>> weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
>>>>>> 'Obtain a unique session based id for the temporary weblayout (which
>>>>>> is a copy of an existing WebLayout) Dim tempid as ResourceIdentifier
>>>>>> new ResourceIdentifier(Guid.NewGuid(),
>>>>>> 'Save the layout, otherwise you can't reference it
>>>>>> con.SaveResourceAs(weblayout, tempid)
>>>>>> 'Open the viewer, and use the temporary layout, since the map only
>>>>>> exists in the 'current session, we must use that session, and NOT
>>>>>> supply username/password
>>>>>> 'BEWARE: The session belongs to the Administrator account, so the
>>>>>> user
>>>>>> gets full access to MapGuide (delete, modify, etc.)
>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
>>>>>> Server.UrlEncode(tempid) & "&SESSION=" &
>>>>>> Server.UrlEncode(con.SessionID))
>>>>>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>>>>>> references multiple LayerDefinitions 4. WebLayout, references a
>>>>>>> MapDefinition
>>>>>>> All these items must be in a repository (either Library or Session),
>>>>>>> otherwise they can't be referenced.
>>>>>>> When you write that you want to "create a WebLayout
>>>>>>> programatically",
>>>>>>> do you want to create ALL the above items, or do you have layers and
>>>>>>> featuresources?
>>>>>>> (1) If you want to generate a WebLayout ResourceID, you should use:
>>>>>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>>>>>> ResourceTypes.WebLayout)
>>>>>>> If you want to read the name of an existing MapDefinition from
>>>>>>> another layout, you must do:
>>>>>>> Dim weblayout as WebLayout =
>>>>>>> Dim res as String = webLayout.Map.ResourceId
>>>>>>> (2) I don't understand the question.
>>>>>>> (3) The MapDefinition is an Xml document. Inside, it references
>>>>>>> layers, which references featuresources, as described above. It is
>>>>>>> very slow to do this, so when you open a map in the browser, the xml
>>>>>>> is transformed into a binary object. This object contains all the
>>>>>>> info from the MapDefinition and some info from the layers and
>>>>>>> featuresources.
>>>>>>> You need to know this, because if you try to toggle layer visibility
>>>>>>> in the MapDefinition, nothing happens. In short, the Runtime Map is
>>>>>>> a
>>>>>>> binary object that you can manipulate using the MapGuide (and
>>>>>>> Maestro)-API, and it only works for a displayed map.
>>>>>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>>>>>> was created from.
>>>>>>> A short example of using an existing WebLayout:
>>>>>>> Dim host As New
>>>>>>> "en", True)
>>>>>>> weblayout.Map.InitialView = new MapViewType()
>>>>>>> weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
>>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim tempid
>>>>>>> as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
>>>>>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>>>>>>> Hi,
>>>>>>>> actually i wrote the code as
>>>>>>>>     Dim host As New
>>>>>>>> "admin", "en", True)
>>>>>>>> data/Maps/mapdata",
>>>>>>>> ResourceTypes.MapDefinition)
>>>>>>>>         Dim mapId As String = res.ResourceId
>>>>>>>> with that i got the map resource id.
>>>>>>>> But actually to run the application the url in the browser must be
>>>>>>>> like
>>>>>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>>>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>>>>>> 1) How can i get this weblayout (like
>>>>>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>>>>>> programmetically
>>>>>>>> 2) I want to redirect to the ajax viewer sample application through
>>>>>>>> asp.net (like given by u )
>>>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>>>>>> for
>>>>>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>>>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>>>>>> configusing
>>>>>>>> state)
>>>>>>>>> Instead of re-posting the original question, could you try to
>>>>>>>>> explain what parts of my previous reply that are unclear or wrong?
>>>>>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>>>>>> 704038.html#a20769349
>>>>>>>>>>   Hi ,
>>>>>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1) Iam
>>>>>>>>>> using dotnet viewer sample while running the application i
>>>>>>>>>> observed that the layout path given in the application.
>>>>>>>>>> as
>>>>>>>>>> String webLayout =
>>>>>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>>>>>>   it works but now i want to create this weblayout in run time
>>>>>>>>>> (by
>>>>>>>>>> code)
>>>>>>>>>> using mapguide maestro api
>>>>>>>>>> for this purpose i followed the link
>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>>>>>> timeMap
>>>>>>>>>> but i didnt get any out.
>>>>>>>>>> can u plz tell me
>>>>>>>>>> 1) how to create this weblayout in run time
>>>>>>>>>> 2) How it will works
>>>>>>>>>> If u know this plz tell me the procedure.
>>>>>>>>>> Regards,
>>>>>>>>>> Padmini.
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> View this message in context:
>>>>> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>>> signature
>>>>> database 3658 (20081202) __________
>>>>> The message was checked by ESET NOD32 Antivirus.
>>>>> http://www.eset.com
>>>>>       __________________________________________________________
>>>>> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
>>>>> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
View this message in context: http://www.nabble.com/Runtime-map-problem-tp20789983p20811652.html
