[mapguide-users] SV: Runtime map problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 3 15:31:45 EST 2008
No, I have no sample code.
The only avalible code I know of, is listed on these two pages:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks again.
> Can u tell me  the sample application for Runtime map ( sample code)
> so that i can learn it and i will convert it for oracle conversion
> Thanks and Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> In that case, you will do something different.
>> You need to setup the layer to display all points correctly.
>> Use Studio or Maestro to accomplish this.
>> When the user needs to view the layer, you do this:
>> 1. Get a copy of the LayerDefinition
>> 2. Modify the "FILTER" property of the LayerDefinition to display only
>> the required data, eg: "ID > 500 AND ID < 510".
>> 3. Save the copy in the session repository under a random name.
>> 4. Get the runtime map, and either
>> 5a. Replace the resourceId of an existing layer with the one from step 3,
>> or
>> 5b. Insert a new layer into the runtime map, pointing to the temporary
>> layerdefinition from step 3
>> 6. Make sure the layer from step 5 is visible
>> 7. Save the modified runtime map
>> 8. Refresh the client.
>> If your map already contains the layer to be show, choose 5a, otherwise
>> choose 5b.
>>> Hi,
>>> Thank u very much for u r reply.
>>> I will check it out .
>>> My Doubt is that
>>> 1) If i create a package in mapguide maestro , connecing to the oracle
>>> how
>>> can access the data using queries.
>>>    suppose i create a feature  resource for a table data in oracle after
>>> that i followed all the procedure and created a package successfully. If
>>> user wants to query this table and wants to display only some of the
>>> features on the map dynamically .How can i provide this?
>>> If u know this plz help me
>>> Regards,
>>> Padmini.
>>>> There is not much I can say to help you there.
>>>> It is very difficult to create LayerDefinitions and WebLayouts
>>>> programatically.
>>>> The problem with creating a LayerDefinition is the number of properties
>>>> you have to set.
>>>> Such properties include, scalerange, point styles, rules, fonts,
>>>> linewidth, colors, etc.
>>>> The WebLayout has all the buttons and menu items.
>>>> I would recommend you reconsider alternatives.
>>>> To create a new LayerDefinition, simply do:
>>>> Dim layerdefinition as new MaestroAPI.LayerDefinition()
>>>> You can use the same approach for any of the other items.
>>>> Then you can save it as you like, using con.SaveResourceAs(...).
>>>> There is no help anywhere, that explains what properties to set.
>>>> You can look in the Maestro code, or examine the Sheboygan
>>>> LayerDefinitions to see what happens.
>>>> A simple shortcut, would be to create a "template" from Maestro, and
>>>> then
>>>> use that template when you start out. You can then modify the template,
>>>> and save it as a resource. To produce a "template", simply create a new
>>>> LayerDefinition
>>>> in Maestro, and then click the "Edit Xml". Copy-n-paste the Xml to a
>>>> file (say C:\template.xml).
>>>> To load a template as an object, you can use (C# code, can never
>>>> remember generics in VB):
>>>> MaestroAPI.LayerDefinition layerdefinition;
>>>> using(System.IO.FileStream fs =
>>>> System.IO.File.OpenRead("C:\\template.xml"))
>>>>     layerdefintion =
>>>> con.DeserializeObject<MaestroAPI.LayerDefinition>(fs);
>>>> You can then modify the geometry column, featuresource pointer, columns,
>>>> filter, tooltip and other items, until it fits the newly uploaded
>>>> SHP file. As I said, it will be dificult, and there is no help avalible
>>>> for the task. Your primary tool is the error log:
>>>> C:\program files\mapguideopensource2.0\server\logs\error.log
>>>> Good luck.
>>>>> Hi,
>>>>> Thanks .its working fine now.
>>>>> To build a map, you must have all the components:
>>>>> 1. FeatureSource, references data
>>>>> 2. LayerDefinition, references a FeatureSource
>>>>> 3. MapDefinition, references multiple LayerDefinitions
>>>>> 4. WebLayout, references a MapDefinition
>>>>> All these items must be in a repository (either Library or Session)
>>>>> I know the procedure to create it in mapguide maestro.
>>>>>    1) Now my problem was  i want to create   ALL the above items
>>>>> programmetically (my input is only a shape file)  byusing maestro dll.
>>>>> Regards,
>>>>> Padmini.
>>>>>> I wrote a follow up, with corrected code.
>>>>>> You are using the initial one, and you are missing a "?" mark in the
>>>>>> redirect URL.
>>>>>> Try to use the updated version, and beware of the question mark in the
>>>>>> Response.Redirect call.
>>>>>>> Hi,
>>>>>>> Thanks for u r reply.
>>>>>>> I tried this code but i got an error that
>>>>>>> Server Error in '/maestro' Application.
>>>>>>> HTTP Error 400 - Bad Request.
>>>>>>> Version Information: ASP.NET Development Server 8.0.0.0
>>>>>>> my code was
>>>>>>>     Dim host As New
>>>>>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>>>>>>         Dim conn As New HttpServerConnection(host, "Administrator",
>>>>>>> "admin",
>>>>>>> "en", True)
>>>>>>>         'You have to change the string below to point at a valid
>>>>>>> WebLayout
>>>>>>>         Dim weblayout As WebLayout =
>>>>>>> conn.GetWebLayout("Library://Filebased
>>>>>>> data/Layout/layout.WebLayout")
>>>>>>>         Dim mapdefinition As MapDefinition =
>>>>>>> conn.GetMapDefinition(weblayout.Map.ResourceId)
>>>>>>>         weblayout.Map.InitialView = New MapViewType()
>>>>>>>         weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
>>>>>>>         weblayout.Map.InitialView.CenterX =
>>>>>>> (mapdefinition.Extents.MaxX
>>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
>>>>>>>         weblayout.Map.InitialView.CenterY =
>>>>>>> (mapdefinition.Extents.MaxY
>>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
>>>>>>>         Dim tempid As ResourceIdentifier = New
>>>>>>> ResourceIdentifier("layout",
>>>>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
>>>>>>>         Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
>>>>>>> Server.UrlEncode(tempid)
>>>>>>> joscsu wrote:
>>>>>>>>  Or this:
>>>>>>>> System.Guid.NewGuid().ToString()
>>>>>>>> ----- Ursprungligt meddelande ----
>>>>>>>> Från: Maksim Sestic <max at geoinova.com>
>>>>>>>> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>>>>>>> Skickat: tisdag 2 december 2008 16:49:21
>>>>>>>> Ämne: RE: [mapguide-users] Runtime map problem
>>>>>>>> Try this:
>>>>>>>> -----Original Message-----
>>>>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>>>>>>> godavarthi
>>>>>>>> Sent: Tuesday, December 02, 2008 15:35
>>>>>>>> To: mapguide-users at lists.osgeo.org
>>>>>>>> Subject: Re: [mapguide-users] Runtime map problem
>>>>>>>> Hi,
>>>>>>>> Thanku very much for ur help
>>>>>>>> i tried this code
>>>>>>>> but i got an error in the line
>>>>>>>> Dim tempid as ResourceIdentifier = new
>>>>>>>> ResourceIdentifier(Guid.NewGuid(),
>>>>>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
>>>>>>>> because of this Guid.NewGuid()
>>>>>>>> 1) Actually what is this?
>>>>>>>> 2) Which paramater we have to pass in this place instead of
>>>>>>>> Guid.NewGuid()
>>>>>>>> Regards,
>>>>>>>> Padmini
>>>>>>>>> I forgot to save the weblayout in the code below :(
>>>>>>>>> Updated version is:
>>>>>>>>> 'Setup connection
>>>>>>>>> Dim host As New
>>>>>>>>> "admin",
>>>>>>>>> "en", True)
>>>>>>>>> 'You have to change the string below to point at a valid WebLayout
>>>>>>>>> Dim
>>>>>>>>> weblayout as WebLayout =
>>>>>>>>> con.GetWebLayout("Library://mylayout.WebLayout")
>>>>>>>>> Dim mapdefinition as MapDefinition =
>>>>>>>>> con.GetMapDefinition(weblayout.Map.ResourceId)
>>>>>>>>> 'Modify the initial view of the weblayout weblayout.Map.InitialView
>>>>>>>>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>>>>>>>>> 1:2000 weblayout.Map.InitialView.CenterX =
>>>>>>>>> weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
>>>>>>>>> 'Obtain a unique session based id for the temporary weblayout
>>>>>>>>> (which
>>>>>>>>> is a copy of an existing WebLayout) Dim tempid as
>>>>>>>>> ResourceIdentifier
>>>>>>>>> new ResourceIdentifier(Guid.NewGuid(),
>>>>>>>>> 'Save the layout, otherwise you can't reference it
>>>>>>>>> con.SaveResourceAs(weblayout, tempid)
>>>>>>>>> 'Open the viewer, and use the temporary layout, since the map only
>>>>>>>>> exists in the 'current session, we must use that session, and NOT
>>>>>>>>> supply username/password
>>>>>>>>> 'BEWARE: The session belongs to the Administrator account, so the
>>>>>>>>> user
>>>>>>>>> gets full access to MapGuide (delete, modify, etc.)
>>>>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
>>>>>>>>> Server.UrlEncode(tempid) & "&SESSION=" &
>>>>>>>>> Server.UrlEncode(con.SessionID))
>>>>>>>>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>>>>>>>>> references multiple LayerDefinitions 4. WebLayout, references a
>>>>>>>>>> MapDefinition
>>>>>>>>>> Session),
>>>>>>>>>> otherwise they can't be referenced.
>>>>>>>>>> When you write that you want to "create a WebLayout
>>>>>>>>>> programatically",
>>>>>>>>>> do you want to create ALL the above items, or do you have layers
>>>>>>>>>> and
>>>>>>>>>> featuresources?
>>>>>>>>>> (1) If you want to generate a WebLayout ResourceID, you should
>>>>>>>>>> use:
>>>>>>>>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>>>>>>>>> ResourceTypes.WebLayout)
>>>>>>>>>> If you want to read the name of an existing MapDefinition from
>>>>>>>>>> another layout, you must do:
>>>>>>>>>> Dim weblayout as WebLayout =
>>>>>>>>>> Dim res as String = webLayout.Map.ResourceId
>>>>>>>>>> (2) I don't understand the question.
>>>>>>>>>> (3) The MapDefinition is an Xml document. Inside, it references
>>>>>>>>>> layers, which references featuresources, as described above. It is
>>>>>>>>>> very slow to do this, so when you open a map in the browser, the
>>>>>>>>>> xml
>>>>>>>>>> is transformed into a binary object. This object contains all the
>>>>>>>>>> info from the MapDefinition and some info from the layers and
>>>>>>>>>> featuresources.
>>>>>>>>>> You need to know this, because if you try to toggle layer
>>>>>>>>>> visibility
>>>>>>>>>> in the MapDefinition, nothing happens. In short, the Runtime Map
>>>>>>>>>> is
>>>>>>>>>> a
>>>>>>>>>> binary object that you can manipulate using the MapGuide (and
>>>>>>>>>> Maestro)-API, and it only works for a displayed map.
>>>>>>>>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>>>>>>>>> was created from.
>>>>>>>>>> A short example of using an existing WebLayout:
>>>>>>>>>> Dim host As New
>>>>>>>>>> "admin",
>>>>>>>>>> "en", True)
>>>>>>>>>> weblayout.Map.InitialView = new MapViewType()
>>>>>>>>>> weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
>>>>>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim
>>>>>>>>>> tempid
>>>>>>>>>> as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
>>>>>>>>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>>>>>>>>>> Hi,
>>>>>>>>>>> actually i wrote the code as
>>>>>>>>>>>     Dim host As New
>>>>>>>>>>> "Administrator",
>>>>>>>>>>> "admin", "en", True)
>>>>>>>>>>> data/Maps/mapdata",
>>>>>>>>>>> ResourceTypes.MapDefinition)
>>>>>>>>>>>         Dim mapId As String = res.ResourceId
>>>>>>>>>>> with that i got the map resource id.
>>>>>>>>>>> But actually to run the application the url in the browser must
>>>>>>>>>>> be
>>>>>>>>>>> like
>>>>>>>>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>>>>>>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>>>>>>>>> 1) How can i get this weblayout (like
>>>>>>>>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>>>>>>>>> programmetically
>>>>>>>>>>> 2) I want to redirect to the ajax viewer sample application
>>>>>>>>>>> through
>>>>>>>>>>> asp.net (like given by u )
>>>>>>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>>>>>>>>> for
>>>>>>>>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>>>>>>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>>>>>>>>> configusing
>>>>>>>>>>> state)
>>>>>>>>>>>> Instead of re-posting the original question, could you try to
>>>>>>>>>>>> explain what parts of my previous reply that are unclear or
>>>>>>>>>>>> wrong?
>>>>>>>>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>>>>>>>>> 704038.html#a20769349
>>>>>>>>>>>>>   Hi ,
>>>>>>>>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1)
>>>>>>>>>>>>> Iam
>>>>>>>>>>>>> using dotnet viewer sample while running the application i
>>>>>>>>>>>>> observed that the layout path given in the application.
>>>>>>>>>>>>> as
>>>>>>>>>>>>> String webLayout =
>>>>>>>>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>>>>>>>>>   it works but now i want to create this weblayout in run time
>>>>>>>>>>>>> (by
>>>>>>>>>>>>> code)
>>>>>>>>>>>>> using mapguide maestro api
>>>>>>>>>>>>> for this purpose i followed the link
>>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>>>>>>>>> timeMap
>>>>>>>>>>>>> but i didnt get any out.
>>>>>>>>>>>>> can u plz tell me
>>>>>>>>>>>>> 1) how to create this weblayout in run time
>>>>>>>>>>>>> 2) How it will works
>>>>>>>>>>>>> If u know this plz tell me the procedure.
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>> View this message in context:
>>>>>>>> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>>>>>> signature
>>>>>>>> database 3658 (20081202) __________
>>>>>>>> The message was checked by ESET NOD32 Antivirus.
>>>>>>>> http://www.eset.com
>>>>>>>>       __________________________________________________________
>>>>>>>> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
>>>>>>>> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081203/107542c6/attachment.html
