[mapguide-users] SV: Runtime map problem
padmini godavarthi godavarthi.padmini at gmail.com
Wed Dec 3 07:55:36 EST 2008
Thanks again.
Can u tell me  the sample application for Runtime map ( sample code)
so that i can learn it and i will convert it for oracle conversion
Thanks and Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> In that case, you will do something different.
> You need to setup the layer to display all points correctly.
> Use Studio or Maestro to accomplish this.
> When the user needs to view the layer, you do this:
> 1. Get a copy of the LayerDefinition
> 2. Modify the "FILTER" property of the LayerDefinition to display only
> the required data, eg: "ID > 500 AND ID < 510".
> 3. Save the copy in the session repository under a random name.
> 4. Get the runtime map, and either
> 5a. Replace the resourceId of an existing layer with the one from step 3,
> or
> 5b. Insert a new layer into the runtime map, pointing to the temporary
> layerdefinition from step 3
> 6. Make sure the layer from step 5 is visible
> 7. Save the modified runtime map
> 8. Refresh the client.
> If your map already contains the layer to be show, choose 5a, otherwise
> choose 5b.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thank u very much for u r reply.
>> I will check it out .
>> My Doubt is that
>> 1) If i create a package in mapguide maestro , connecing to the oracle
>> how
>> can access the data using queries.
>>    suppose i create a feature  resource for a table data in oracle after
>> that i followed all the procedure and created a package successfully. If
>> user wants to query this table and wants to display only some of the
>> features on the map dynamically .How can i provide this?
>> If u know this plz help me
>> Regards,
>> Padmini.
>>> There is not much I can say to help you there.
>>> It is very difficult to create LayerDefinitions and WebLayouts
>>> programatically.
>>> The problem with creating a LayerDefinition is the number of properties
>>> you have to set.
>>> Such properties include, scalerange, point styles, rules, fonts,
>>> linewidth, colors, etc.
>>> The WebLayout has all the buttons and menu items.
>>> I would recommend you reconsider alternatives.
>>> To create a new LayerDefinition, simply do:
>>> Dim layerdefinition as new MaestroAPI.LayerDefinition()
>>> You can use the same approach for any of the other items.
>>> Then you can save it as you like, using con.SaveResourceAs(...).
>>> There is no help anywhere, that explains what properties to set.
>>> You can look in the Maestro code, or examine the Sheboygan
>>> LayerDefinitions to see what happens.
>>> A simple shortcut, would be to create a "template" from Maestro, and
>>> then
>>> use that template when you start out. You can then modify the template,
>>> and save it as a resource. To produce a "template", simply create a new
>>> LayerDefinition
>>> in Maestro, and then click the "Edit Xml". Copy-n-paste the Xml to a
>>> file (say C:\template.xml).
>>> To load a template as an object, you can use (C# code, can never
>>> remember generics in VB):
>>> MaestroAPI.LayerDefinition layerdefinition;
>>> using(System.IO.FileStream fs =
>>> System.IO.File.OpenRead("C:\\template.xml"))
>>>     layerdefintion =
>>> con.DeserializeObject<MaestroAPI.LayerDefinition>(fs);
>>> You can then modify the geometry column, featuresource pointer, columns,
>>> filter, tooltip and other items, until it fits the newly uploaded
>>> SHP file. As I said, it will be dificult, and there is no help avalible
>>> for the task. Your primary tool is the error log:
>>> C:\program files\mapguideopensource2.0\server\logs\error.log
>>> Good luck.
>>>> Hi,
>>>> Thanks .its working fine now.
>>>> To build a map, you must have all the components:
>>>> 1. FeatureSource, references data
>>>> 2. LayerDefinition, references a FeatureSource
>>>> 3. MapDefinition, references multiple LayerDefinitions
>>>> 4. WebLayout, references a MapDefinition
>>>> All these items must be in a repository (either Library or Session)
>>>> I know the procedure to create it in mapguide maestro.
>>>>    1) Now my problem was  i want to create   ALL the above items
>>>> programmetically (my input is only a shape file)  byusing maestro dll.
>>>> Regards,
>>>> Padmini.
>>>>> I wrote a follow up, with corrected code.
>>>>> You are using the initial one, and you are missing a "?" mark in the
>>>>> redirect URL.
>>>>> Try to use the updated version, and beware of the question mark in the
>>>>> Response.Redirect call.
>>>>>> Hi,
>>>>>> Thanks for u r reply.
>>>>>> I tried this code but i got an error that
>>>>>> Server Error in '/maestro' Application.
>>>>>> HTTP Error 400 - Bad Request.
>>>>>> Version Information: ASP.NET Development Server 8.0.0.0
>>>>>> my code was
>>>>>>     Dim host As New
>>>>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>>>>>         Dim conn As New HttpServerConnection(host, "Administrator",
>>>>>> "admin",
>>>>>> "en", True)
>>>>>>         'You have to change the string below to point at a valid
>>>>>> WebLayout
>>>>>>         Dim weblayout As WebLayout =
>>>>>> conn.GetWebLayout("Library://Filebased
>>>>>> data/Layout/layout.WebLayout")
>>>>>>         Dim mapdefinition As MapDefinition =
>>>>>> conn.GetMapDefinition(weblayout.Map.ResourceId)
>>>>>>         weblayout.Map.InitialView = New MapViewType()
>>>>>>         weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
>>>>>>         weblayout.Map.InitialView.CenterX =
>>>>>> (mapdefinition.Extents.MaxX
>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
>>>>>>         weblayout.Map.InitialView.CenterY =
>>>>>> (mapdefinition.Extents.MaxY
>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
>>>>>>         Dim tempid As ResourceIdentifier = New
>>>>>> ResourceIdentifier("layout",
>>>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
>>>>>>         Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
>>>>>> Server.UrlEncode(tempid)
>>>>>> joscsu wrote:
>>>>>>>  Or this:
>>>>>>> System.Guid.NewGuid().ToString()
>>>>>>> ----- Ursprungligt meddelande ----
>>>>>>> Från: Maksim Sestic <max at geoinova.com>
>>>>>>> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>>>>>> Skickat: tisdag 2 december 2008 16:49:21
>>>>>>> Ämne: RE: [mapguide-users] Runtime map problem
>>>>>>> Try this:
>>>>>>> -----Original Message-----
>>>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>>>>>> godavarthi
>>>>>>> Sent: Tuesday, December 02, 2008 15:35
>>>>>>> To: mapguide-users at lists.osgeo.org
>>>>>>> Subject: Re: [mapguide-users] Runtime map problem
>>>>>>> Hi,
>>>>>>> Thanku very much for ur help
>>>>>>> i tried this code
>>>>>>> but i got an error in the line
>>>>>>> Dim tempid as ResourceIdentifier = new
>>>>>>> ResourceIdentifier(Guid.NewGuid(),
>>>>>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
>>>>>>> because of this Guid.NewGuid()
>>>>>>> 1) Actually what is this?
>>>>>>> 2) Which paramater we have to pass in this place instead of
>>>>>>> Guid.NewGuid()
>>>>>>> Regards,
>>>>>>> Padmini
>>>>>>>> I forgot to save the weblayout in the code below :(
>>>>>>>> Updated version is:
>>>>>>>> 'Setup connection
>>>>>>>> Dim host As New
>>>>>>>> "admin",
>>>>>>>> "en", True)
>>>>>>>> 'You have to change the string below to point at a valid WebLayout
>>>>>>>> Dim
>>>>>>>> weblayout as WebLayout =
>>>>>>>> con.GetWebLayout("Library://mylayout.WebLayout")
>>>>>>>> Dim mapdefinition as MapDefinition =
>>>>>>>> con.GetMapDefinition(weblayout.Map.ResourceId)
>>>>>>>> 'Modify the initial view of the weblayout weblayout.Map.InitialView
>>>>>>>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>>>>>>>> 1:2000 weblayout.Map.InitialView.CenterX =
>>>>>>>> weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
>>>>>>>> 'Obtain a unique session based id for the temporary weblayout
>>>>>>>> (which
>>>>>>>> is a copy of an existing WebLayout) Dim tempid as
>>>>>>>> ResourceIdentifier
>>>>>>>> new ResourceIdentifier(Guid.NewGuid(),
>>>>>>>> 'Save the layout, otherwise you can't reference it
>>>>>>>> con.SaveResourceAs(weblayout, tempid)
>>>>>>>> 'Open the viewer, and use the temporary layout, since the map only
>>>>>>>> exists in the 'current session, we must use that session, and NOT
>>>>>>>> supply username/password
>>>>>>>> 'BEWARE: The session belongs to the Administrator account, so the
>>>>>>>> user
>>>>>>>> gets full access to MapGuide (delete, modify, etc.)
>>>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
>>>>>>>> Server.UrlEncode(tempid) & "&SESSION=" &
>>>>>>>> Server.UrlEncode(con.SessionID))
>>>>>>>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>>>>>>>> references multiple LayerDefinitions 4. WebLayout, references a
>>>>>>>>> MapDefinition
>>>>>>>>> Session),
>>>>>>>>> otherwise they can't be referenced.
>>>>>>>>> When you write that you want to "create a WebLayout
>>>>>>>>> programatically",
>>>>>>>>> do you want to create ALL the above items, or do you have layers
>>>>>>>>> and
>>>>>>>>> featuresources?
>>>>>>>>> (1) If you want to generate a WebLayout ResourceID, you should
>>>>>>>>> use:
>>>>>>>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>>>>>>>> ResourceTypes.WebLayout)
>>>>>>>>> If you want to read the name of an existing MapDefinition from
>>>>>>>>> another layout, you must do:
>>>>>>>>> Dim weblayout as WebLayout =
>>>>>>>>> Dim res as String = webLayout.Map.ResourceId
>>>>>>>>> (2) I don't understand the question.
>>>>>>>>> (3) The MapDefinition is an Xml document. Inside, it references
>>>>>>>>> layers, which references featuresources, as described above. It is
>>>>>>>>> very slow to do this, so when you open a map in the browser, the
>>>>>>>>> xml
>>>>>>>>> is transformed into a binary object. This object contains all the
>>>>>>>>> info from the MapDefinition and some info from the layers and
>>>>>>>>> featuresources.
>>>>>>>>> You need to know this, because if you try to toggle layer
>>>>>>>>> visibility
>>>>>>>>> in the MapDefinition, nothing happens. In short, the Runtime Map
>>>>>>>>> is
>>>>>>>>> a
>>>>>>>>> binary object that you can manipulate using the MapGuide (and
>>>>>>>>> Maestro)-API, and it only works for a displayed map.
>>>>>>>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>>>>>>>> was created from.
>>>>>>>>> A short example of using an existing WebLayout:
>>>>>>>>> Dim host As New
>>>>>>>>> "admin",
>>>>>>>>> "en", True)
>>>>>>>>> weblayout.Map.InitialView = new MapViewType()
>>>>>>>>> weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
>>>>>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim
>>>>>>>>> tempid
>>>>>>>>> as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
>>>>>>>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>>>>>>>>> Hi,
>>>>>>>>>> actually i wrote the code as
>>>>>>>>>>     Dim host As New
>>>>>>>>>> "Administrator",
>>>>>>>>>> "admin", "en", True)
>>>>>>>>>> data/Maps/mapdata",
>>>>>>>>>> ResourceTypes.MapDefinition)
>>>>>>>>>>         Dim mapId As String = res.ResourceId
>>>>>>>>>> with that i got the map resource id.
>>>>>>>>>> But actually to run the application the url in the browser must
>>>>>>>>>> be
>>>>>>>>>> like
>>>>>>>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>>>>>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>>>>>>>> 1) How can i get this weblayout (like
>>>>>>>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>>>>>>>> programmetically
>>>>>>>>>> 2) I want to redirect to the ajax viewer sample application
>>>>>>>>>> through
>>>>>>>>>> asp.net (like given by u )
>>>>>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>>>>>>>> for
>>>>>>>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>>>>>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>>>>>>>> configusing
>>>>>>>>>> state)
>>>>>>>>>>> Instead of re-posting the original question, could you try to
>>>>>>>>>>> explain what parts of my previous reply that are unclear or
>>>>>>>>>>> wrong?
>>>>>>>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>>>>>>>> 704038.html#a20769349
>>>>>>>>>>>>   Hi ,
>>>>>>>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1)
>>>>>>>>>>>> Iam
>>>>>>>>>>>> using dotnet viewer sample while running the application i
>>>>>>>>>>>> observed that the layout path given in the application.
>>>>>>>>>>>> as
>>>>>>>>>>>> String webLayout =
>>>>>>>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>>>>>>>>   it works but now i want to create this weblayout in run time
>>>>>>>>>>>> (by
>>>>>>>>>>>> code)
>>>>>>>>>>>> using mapguide maestro api
>>>>>>>>>>>> for this purpose i followed the link
>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>>>>>>>> timeMap
>>>>>>>>>>>> but i didnt get any out.
>>>>>>>>>>>> can u plz tell me
>>>>>>>>>>>> 1) how to create this weblayout in run time
>>>>>>>>>>>> 2) How it will works
>>>>>>>>>>>> If u know this plz tell me the procedure.
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Padmini.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>> View this message in context:
>>>>>>> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>>>>> signature
>>>>>>> database 3658 (20081202) __________
>>>>>>> The message was checked by ESET NOD32 Antivirus.
>>>>>>> http://www.eset.com
>>>>>>>       __________________________________________________________
>>>>>>> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
>>>>>>> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
View this message in context: http://www.nabble.com/Runtime-map-problem-tp20789983p20812457.html
