[mapguide-users] Jx Layout and Fusion
Paul Spencer pagameba at gmail.com
Thu Dec 4 08:32:50 EST 2008
Hi Mark,
this is probably something to do with Jx.  Jx.Layout is used to make
things fill their containers, it sounds like you are missing
something.  Perhaps if you post your code+html+css we could advise
you ...
Cheers
Paul
On 3-Dec-08, at 1:46 PM, Mark Pendergraft wrote:
> I have a question about the Jx libraries in relation to Fusion.  I'm
> trying to build my own layout for fusion similar to the aqua layout
> supplied with MGOS.  I would like the Legend, SelectionPanel, and
> Task Pane to show up as tabs in a dialog.  The code works and they
> are displayed as such, but the tabbox doesn't take up the entire
> dialog, so there are scroll bars up/down and left/right and there is
> blank space on the bottom and right of the dialog that the tabbox
> sits in.  There is also blank space on the bottom of the dialog that
> I have created for the overview map, even though I used the same
> exact code as the provided template.  Is this a Jx issue, or are the
> sizes of the controls handled in another part of the code?
> I looked in the css for the template, and I didn’t see anything.
> Also, If I create separate dialog boxes for all three elements
> (taskpane, selectionpanel, and legend) than each element fills it's
> dialog completely like it's supposed to.
> Thanks for the help!
> -Mark Pendergraft
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
