[mapguide-users] Problem loading shp into mapguide using
maestro. Missing attribute info
kyedinak
admin at hitechvalue.net
Thu Dec 4 08:44:08 EST 2008
Guys,
In order for your attribute fields to show up in the layer, you must add the
dbf file to your shapefile resource. For example, if you have a data
resource that has test_poly.shp in it, open that resource and click the
green plus sign and add the test_poly.dbf file. Click the Test Connection
button to verify all is well.
Save the resource then open up your layer that is using the test_poly info.
Your fields should show up in the list.
Hope that helps.
Kirk
View this message in context: http://www.nabble.com/Problem-loading-shp-into-mapguide-using-maestro.-Missing-attribute-info-tp19241857p20153838.html
