[mapguide-users] gettile method problems
alucas alucas at srtec.com
Sat Dec 6 12:13:13 EST 2008
Hello all,
I'm trying to develop a tile pre-generation desktop application. To do this,
I'm using mapguidedotnetapi.dll reference. My program creates a connection
to the server and through the tileservice try to call gettile method for
every tile. My problem is that gettile method fails and returns an xmlstream
exception, then I need to restart the server service because I get a
connection exception.
This is the exception:
http://www.nabble.com/file/p20872280/exception.jpg
The exception happens not in the first gettile call, it happens when I
called several times this method. My program is something like this:
for each scalecount
  for each column
    for each row
      tileService.GetTile(mapResId, layerGroupName, c, r, s)
Solutions I tried:
- Modify serverconfig.ini to enable poolconnections for my data.
- Use thread.sleep between iterations
- Use a separate thread to do this work
- Generate tiles only for a scale factor.
This solutions does not work for me.
Any idea?
Sorry for my english...
Thanks in advance
View this message in context: http://www.nabble.com/gettile-method-problems-tp20872280p20872280.html
