[mapguide-users] gettile method problems
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Dec 7 13:12:35 EST 2008
I can't tell you exactly what goes wrong, but work for a tile generator
has been done elsewhere.
The FMTilingEngine prepares tiles, and automatically restarts the
MapGuide service when it encounters the problem:
http://www.websoftdev.com/download.cfm
Zac has developed a browser based tile seeder:
http://zacster.blogspot.com/2008/07/mapguide-tile-cache-seeder.html
I am building a tile seeder for use with Maestro (not complete, and not
released, LGPL):
http://svn.osgeo.org/mapguide/trunk/Tools/Maestro/MgCooker/
Perhaps the FMTilingEngine will solve your troubles.
If not, you can consider building on one of the other solutions.
Regards, Kenneth Skovhede, GEOGRAF A/S
alucas skrev:
> Hello all,
> I'm trying to develop a tile pre-generation desktop application. To do this,
> I'm using mapguidedotnetapi.dll reference. My program creates a connection
> to the server and through the tileservice try to call gettile method for
> every tile. My problem is that gettile method fails and returns an xmlstream
> exception, then I need to restart the server service because I get a
> connection exception.
> This is the exception:
> http://www.nabble.com/file/p20872280/exception.jpg
> The exception happens not in the first gettile call, it happens when I
> called several times this method. My program is something like this:
> for each scalecount
>   for each column
>     for each row
>       tileService.GetTile(mapResId, layerGroupName, c, r, s)
> Solutions I tried:
> - Modify serverconfig.ini to enable poolconnections for my data.
> - Use thread.sleep between iterations
> - Use a separate thread to do this work
> - Generate tiles only for a scale factor.
> This solutions does not work for me.
> Any idea?
> Sorry for my english...
> Thanks in advance
