[mapguide-users] gettile method problems
alucas
alucas at srtec.com
Mon Dec 8 12:14:05 EST 2008
Hello Kenneth,
If after call GetTile I write the tile in a temporary directory, then the
service does not goes down. Strange behaviour...
Now my code looks something like this:
for (int s = scaleCount -1; s >=0; s--)
// nTilesX and nTilesY calculation
for (int r = 0; r <= nTilesX; r++)
for (int c = 0; c <= nTilesY; c++)
MgByteReader br = ts.GetTile(mapResId, layerGroup, c, r, s);
MgByteSink bs = new MgByteSink(br);
bs.ToFile(@"c:\Temp\s"+ s.ToString() +"_r"+r.ToString()+"_c"+
c.ToString()+".jpg");
If I comment the lines for write the tiles, then I get the exception again.
Any Idea?
Kenneth Skovhede, GEOGRAF A/S wrote:
> I can't tell you exactly what goes wrong, but work for a tile generator
> has been done elsewhere.
> The FMTilingEngine prepares tiles, and automatically restarts the
> MapGuide service when it encounters the problem:
> http://www.websoftdev.com/download.cfm
> Zac has developed a browser based tile seeder:
> http://zacster.blogspot.com/2008/07/mapguide-tile-cache-seeder.html
> I am building a tile seeder for use with Maestro (not complete, and not
> released, LGPL):
> http://svn.osgeo.org/mapguide/trunk/Tools/Maestro/MgCooker/
> Perhaps the FMTilingEngine will solve your troubles.
> If not, you can consider building on one of the other solutions.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> alucas skrev:
>> Hello all,
>> I'm trying to develop a tile pre-generation desktop application. To do
>> this,
>> I'm using mapguidedotnetapi.dll reference. My program creates a
>> connection
>> to the server and through the tileservice try to call gettile method for
>> every tile. My problem is that gettile method fails and returns an
>> xmlstream
>> exception, then I need to restart the server service because I get a
>> connection exception.
>> This is the exception:
>> http://www.nabble.com/file/p20872280/exception.jpg
>> The exception happens not in the first gettile call, it happens when I
>> called several times this method. My program is something like this:
>> for each scalecount
>> for each column
>> for each row
>> tileService.GetTile(mapResId, layerGroupName, c, r, s)
>> Solutions I tried:
>> - Modify serverconfig.ini to enable poolconnections for my data.
>> - Use thread.sleep between iterations
>> - Use a separate thread to do this work
>> - Generate tiles only for a scale factor.
>> This solutions does not work for me.
>> Any idea?
>> Sorry for my english...
>> Thanks in advance
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/gettile-method-problems-tp20872280p20899422.html
