[mapguide-users] New King.Oracle 0.8 - improved performance
born2bwild
edelaite at mairie-metz.fr
Mon Dec 8 14:51:00 EST 2008
Hi and thanks a lot,
I don't use KingFdoClass.
I always use OracleSchema connection property, but I tried without : same
problem.
I've tried with the same owner and other owner with full Oracle privilege
(DBA) : same problem.
I've tried with Oracle 9i and 10g (locator, not spatial) : same problem.
Finaly I've tried to activate SQL Trace on both oracle database, to isolate
the problem, but I didn't see anything (I can send you thoses traces for
help).
How can I send you (email) sql, schema and oaner describtions to recreate
the problem ?
Haris Kurtagic wrote:
> Hi,
> It looks like King.Oracle 0.8.x has problems in DescribeSchema in some
> cases.
> I will try to solve in next couple of days.
> Your input could help me to faster find point of error.
> Do you use KinfFdoClass table ?
> Do you use OracleSchema connection property (to use tables from only one
> owner) ?
> And if so is it same owner as the username you use to connect to
> database ?
> You already told so, but to recheck it is same for 9.2 and 10g ?
> If you could isolate problem to one particular table and send me SQL to
> recreate that table, that could help.
> Thanks,
> Haris
View this message in context: http://n2.nabble.com/New-King.Oracle-0.8---improved-performance-tp1519120p1630603.html
