[mapguide-users] New King.Oracle 0.8 - improved performance
Haris Kurtagic
haris at sl-king.com
Mon Dec 8 12:11:23 EST 2008
It looks like King.Oracle 0.8.x has problems in DescribeSchema in some
cases.
I will try to solve in next couple of days.
Your input could help me to faster find point of error.
Do you use KinfFdoClass table ?
Do you use OracleSchema connection property (to use tables from only one
owner) ?
And if so is it same owner as the username you use to connect to
database ?
You already told so, but to recheck it is same for 9.2 and 10g ?
If you could isolate problem to one particular table and send me SQL to
recreate that table, that could help.
Thanks,
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of born2bwild
Sent: Monday, December 08, 2008 2:53 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] New King.Oracle 0.8 - improved performance
Hi and sorry for my poor english,
MGOS 2.0.2
All work fine with king oracle 0.7.4 but, I've a problem with new king
oracle 0.8.5 on Maestro, when i want to select a feature source for a
layer
(i've tested with oracle 9.2i and 10g and instant client from 10.1 to
10.2)
i've always got this error message :
"Failed to read schema from data source. Thet operation gave the error
massage : (559) MgFdoException : An Excetion occured in FDO component.
ORA-00933:SQL command not properly ended
Exception occured in method MgServerDescribeSchema.ExecuteDescribeSchema
at
line 176 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\feature\ServerDescribeSchema.cpp"
In the log file, there is :
Error: An exception occurred in FDO component.
ORA-00933: SQL command not properly ended
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
\feature\FeatureServiceHandler.cpp
- MgOpDescribeSchemaAsXml.Execute line 105 file
\feature\OpDescribeSchemaAsXml.cpp
- MgServerDescribeSchema.DescribeSchemaAsXml line 607 file
- MgServerDescribeSchema.DescribeSchema line 564 file
- MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
Thanks
View this message in context:
http://n2.nabble.com/New-King.Oracle-0.8---improved-performance-tp151912
0p1629093.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
