[mapguide-users] New King.Oracle 0.8 - improved performance
born2bwild edelaite at mairie-metz.fr
Mon Dec 8 08:52:41 EST 2008
Hi and sorry for my poor english,
MGOS 2.0.2
All work fine with king oracle 0.7.4 but, I've a problem with new king
oracle 0.8.5 on Maestro, when i want to select a feature source for a layer
(i've tested with oracle 9.2i and 10g and instant client from 10.1 to 10.2)
i've always got this error message :
"Failed to read schema from data source. Thet operation gave the error
massage : (559) MgFdoException : An Excetion occured in FDO component.
ORA-00933:SQL command not properly ended
Exception occured in method MgServerDescribeSchema.ExecuteDescribeSchema at
line 176 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
In the log file, there is :
Error: An exception occurred in FDO component.
        ORA-00933: SQL command not properly ended
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpDescribeSchemaAsXml.Execute line 105 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
  - MgServerDescribeSchema.DescribeSchemaAsXml line 607 file
  - MgServerDescribeSchema.DescribeSchema line 564 file
  - MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
Thanks
View this message in context: http://n2.nabble.com/New-King.Oracle-0.8---improved-performance-tp1519120p1629093.html
