[mapguide-users] Mapguide server is very slow
Fan Xu
fan at projectmax.co.nz
Sun Dec 14 16:31:04 EST 2008
Hello Z,
The mapguide version is 2.0.2. The map has over 30 layers, some data sources
come from the joins of SHP files and Access database.
I will try to use tiled maps.
Thank you very much.
Fan
zspitzer wrote:
> which mapguide version, what kind of maps?
> using tiled maps will make a big difference, as will using SDF/SHP
> over a database
> z
> On Fri, Dec 12, 2008 at 2:25 PM, Fan Xu <fan at projectmax.co.nz> wrote:
>> We host the mapguide server on our own server. The problem is that the
>> mapguide server is running very slow. When requesting a mapguide page, it
>> takes a while for the map to display.
>> My questions are:
>> 1. Is there anyway to improve the performance of mapguide server? e.g.
>> speeding up the displaying of
>> the map.
>> 2. Is there any hosting services out there that can host mapguide server
>> and
>> the performance is fast?
>> Your help is very appreciated.
>> Thanks in advance.
>> Fan
>> View this message in context:
>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p20969356.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21004905.html
