[mapguide-users] Mapguide server is very slow
Zac Spitzer
zac.spitzer at gmail.com
Sun Dec 14 21:00:47 EST 2008
the joins are most likey the problem, there have been a couple of
posts recently about this
on the mailing list. Alas, currently, feature joins simply are sloooow..
On Mon, Dec 15, 2008 at 8:31 AM, Fan Xu <fan at projectmax.co.nz> wrote:
> Hello Z,
> The mapguide version is 2.0.2. The map has over 30 layers, some data sources
> come from the joins of SHP files and Access database.
> I will try to use tiled maps.
> Thank you very much.
> Fan
> zspitzer wrote:
>> which mapguide version, what kind of maps?
>> using tiled maps will make a big difference, as will using SDF/SHP
>> over a database
>> z
>> On Fri, Dec 12, 2008 at 2:25 PM, Fan Xu <fan at projectmax.co.nz> wrote:
>>> We host the mapguide server on our own server. The problem is that the
>>> mapguide server is running very slow. When requesting a mapguide page, it
>>> takes a while for the map to display.
>>> My questions are:
>>> 1. Is there anyway to improve the performance of mapguide server? e.g.
>>> speeding up the displaying of
>>> the map.
>>> 2. Is there any hosting services out there that can host mapguide server
>>> and
>>> the performance is fast?
>>> Your help is very appreciated.
>>> Thanks in advance.
>>> Fan
>>> View this message in context:
>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p20969356.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
> View this message in context: http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21004905.html
Zac Spitzer -
+61 405 847 168
