[mapguide-users] Mapguide server is very slow
anakando
anakando at yahoo.com
Mon Dec 15 03:35:51 EST 2008
yes agree. mgos performance is decrease after joining a couple of layers with
database. any action taken?
zspitzer wrote:
> the joins are most likey the problem, there have been a couple of
> posts recently about this
> on the mailing list. Alas, currently, feature joins simply are sloooow..
> On Mon, Dec 15, 2008 at 8:31 AM, Fan Xu <fan at projectmax.co.nz> wrote:
>> Hello Z,
>> The mapguide version is 2.0.2. The map has over 30 layers, some data
>> sources
>> come from the joins of SHP files and Access database.
>> I will try to use tiled maps.
>> Thank you very much.
>> Fan
>> zspitzer wrote:
>>> which mapguide version, what kind of maps?
>>> using tiled maps will make a big difference, as will using SDF/SHP
>>> over a database
>>> z
>>> On Fri, Dec 12, 2008 at 2:25 PM, Fan Xu <fan at projectmax.co.nz> wrote:
>>>> We host the mapguide server on our own server. The problem is that the
>>>> mapguide server is running very slow. When requesting a mapguide page,
>>>> it
>>>> takes a while for the map to display.
>>>> My questions are:
>>>> 1. Is there anyway to improve the performance of mapguide server? e.g.
>>>> speeding up the displaying of
>>>> the map.
>>>> 2. Is there any hosting services out there that can host mapguide
>>>> server
>>>> and
>>>> the performance is fast?
>>>> Your help is very appreciated.
>>>> Thanks in advance.
>>>> Fan
>>>> View this message in context:
>>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p20969356.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21004905.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21010029.html
