[mapguide-users] Mapguide server is very slow
Zac Spitzer
zac.spitzer at gmail.com
Mon Dec 15 03:55:01 EST 2008
don't :)
pre cook your data if possible, ie create views and write them out to SDF
z
On Mon, Dec 15, 2008 at 7:35 PM, anakando <anakando at yahoo.com> wrote:
> yes agree. mgos performance is decrease after joining a couple of layers with
> database. any action taken?
> zspitzer wrote:
>> the joins are most likey the problem, there have been a couple of
>> posts recently about this
>> on the mailing list. Alas, currently, feature joins simply are sloooow..
>> On Mon, Dec 15, 2008 at 8:31 AM, Fan Xu <fan at projectmax.co.nz> wrote:
>>> Hello Z,
>>> The mapguide version is 2.0.2. The map has over 30 layers, some data
>>> sources
>>> come from the joins of SHP files and Access database.
>>> I will try to use tiled maps.
>>> Thank you very much.
>>> Fan
>>> zspitzer wrote:
>>>> which mapguide version, what kind of maps?
>>>> using tiled maps will make a big difference, as will using SDF/SHP
>>>> over a database
>>>> z
>>>> On Fri, Dec 12, 2008 at 2:25 PM, Fan Xu <fan at projectmax.co.nz> wrote:
>>>>> We host the mapguide server on our own server. The problem is that the
>>>>> mapguide server is running very slow. When requesting a mapguide page,
>>>>> it
>>>>> takes a while for the map to display.
>>>>> My questions are:
>>>>> 1. Is there anyway to improve the performance of mapguide server? e.g.
>>>>> speeding up the displaying of
>>>>> the map.
>>>>> 2. Is there any hosting services out there that can host mapguide
>>>>> server
>>>>> and
>>>>> the performance is fast?
>>>>> Your help is very appreciated.
>>>>> Thanks in advance.
>>>>> Fan
>>>>> View this message in context:
>>>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p20969356.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com
>>>> +61 405 847 168
>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21004905.html
>> Zac Spitzer -
>> +61 405 847 168
> View this message in context: http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21010029.html
Zac Spitzer -
+61 405 847 168
