[mapguide-users] Mapguide server is very slow
anakando anakando at yahoo.com
Mon Dec 15 04:07:14 EST 2008
Then there is no more dynamic data. Every time want to update the attributes,
i need to create a new sdf file. annoying isn't? lol
zspitzer wrote:
> don't :)
> pre cook your data if possible, ie create views and write them out to SDF
> z
> On Mon, Dec 15, 2008 at 7:35 PM, anakando <anakando at yahoo.com> wrote:
>> yes agree. mgos performance is decrease after joining a couple of layers
>> with
>> database. any action taken?
>> zspitzer wrote:
>>> the joins are most likey the problem, there have been a couple of
>>> posts recently about this
>>> on the mailing list. Alas, currently, feature joins simply are sloooow..
>>> On Mon, Dec 15, 2008 at 8:31 AM, Fan Xu <fan at projectmax.co.nz> wrote:
>>>> Hello Z,
>>>> The mapguide version is 2.0.2. The map has over 30 layers, some data
>>>> sources
>>>> come from the joins of SHP files and Access database.
>>>> I will try to use tiled maps.
>>>> Thank you very much.
>>>> Fan
>>>> zspitzer wrote:
>>>>> which mapguide version, what kind of maps?
>>>>> using tiled maps will make a big difference, as will using SDF/SHP
>>>>> over a database
>>>>> z
>>>>> On Fri, Dec 12, 2008 at 2:25 PM, Fan Xu <fan at projectmax.co.nz> wrote:
>>>>>> We host the mapguide server on our own server. The problem is that
>>>>>> the
>>>>>> mapguide server is running very slow. When requesting a mapguide
>>>>>> page,
>>>>>> it
>>>>>> takes a while for the map to display.
>>>>>> My questions are:
>>>>>> 1. Is there anyway to improve the performance of mapguide server?
>>>>>> e.g.
>>>>>> speeding up the displaying of
>>>>>>    the map.
>>>>>> 2. Is there any hosting services out there that can host mapguide
>>>>>> server
>>>>>> and
>>>>>> the performance is fast?
>>>>>> Your help is very appreciated.
>>>>>> Thanks in advance.
>>>>>> Fan
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p20969356.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com
>>>>> +61 405 847 168
>>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21004905.html
>>> Zac Spitzer -
>>> +61 405 847 168
>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21010029.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21010428.html
