[mapguide-users] Mapguide server is very slow
Jackie C. Ng
jumpinjackie at gmail.com
Mon Dec 15 05:51:09 EST 2008
The question you should ask yourself is do you really need up-to-the-minute
linked data? If not, then what has been previously mentioned is a
satisfactory workaround that solves the performance issues with feature
joins.
- Jackie
anakando wrote:
> Then there is no more dynamic data. Every time want to update the
> attributes, i need to create a new sdf file. annoying isn't? lol
> zspitzer wrote:
>> don't :)
>> pre cook your data if possible, ie create views and write them out to SDF
>> z
>> On Mon, Dec 15, 2008 at 7:35 PM, anakando <anakando at yahoo.com> wrote:
>>> yes agree. mgos performance is decrease after joining a couple of layers
>>> with
>>> database. any action taken?
>>> zspitzer wrote:
>>>> the joins are most likey the problem, there have been a couple of
>>>> posts recently about this
>>>> on the mailing list. Alas, currently, feature joins simply are
>>>> sloooow..
>>>> On Mon, Dec 15, 2008 at 8:31 AM, Fan Xu <fan at projectmax.co.nz> wrote:
>>>>> Hello Z,
>>>>> The mapguide version is 2.0.2. The map has over 30 layers, some data
>>>>> sources
>>>>> come from the joins of SHP files and Access database.
>>>>> I will try to use tiled maps.
>>>>> Thank you very much.
>>>>> Fan
>>>>> zspitzer wrote:
>>>>>> which mapguide version, what kind of maps?
>>>>>> using tiled maps will make a big difference, as will using SDF/SHP
>>>>>> over a database
>>>>>> z
>>>>>> On Fri, Dec 12, 2008 at 2:25 PM, Fan Xu <fan at projectmax.co.nz> wrote:
>>>>>>> We host the mapguide server on our own server. The problem is that
>>>>>>> the
>>>>>>> mapguide server is running very slow. When requesting a mapguide
>>>>>>> page,
>>>>>>> it
>>>>>>> takes a while for the map to display.
>>>>>>> My questions are:
>>>>>>> 1. Is there anyway to improve the performance of mapguide server?
>>>>>>> e.g.
>>>>>>> speeding up the displaying of
>>>>>>> the map.
>>>>>>> 2. Is there any hosting services out there that can host mapguide
>>>>>>> server
>>>>>>> and
>>>>>>> the performance is fast?
>>>>>>> Your help is very appreciated.
>>>>>>> Thanks in advance.
>>>>>>> Fan
>>>>>>> View this message in context:
>>>>>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p20969356.html
>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> Zac Spitzer -
>>>>>> http://zacster.blogspot.com
>>>>>> +61 405 847 168
>>>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21004905.html
>>>> Zac Spitzer -
>>>> +61 405 847 168
>>> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21010029.html
>> Zac Spitzer -
>> +61 405 847 168
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21011726.html
