[mapguide-users] Mapguide server is very slow
Jackie Ng
jumpinjackie at gmail.com
Mon Dec 15 23:19:50 EST 2008
Can you reduce the "surface area" of the data? That is, can you create views
of that table containing only columns you need, and have your layers link to
them instead?
- Jackie
anakando wrote:
> answer for the question is 'yes'. that is why we raised up this issue at
> this
> forum. if we are not concern on the joining performance,i have been
> transported all my data to sdf along time ago. I have 34 layers which all
> layer are joinned to database. Each layer contain at least 30 data. it
> takes
> around 1 minute to load everything into map..30 second to zoom, 47 second
> to
> pan, almost 1 minute to zoom extent.maybe this period of time is short for
> someone who have 40hours in 1 day. so they can keep waiting and waiting
> lol.
> I have controlled the layer scale,visibility,configure server setting to
> increase the performance, but the result is as i mentioned above.
> Jackie C. Ng wrote:
>> The question you should ask yourself is do you really need
>> up-to-the-minute linked data? If not, then what has been previously
>> mentioned is a satisfactory workaround that solves the performance issues
>> with feature joins.
>> - Jackie
> http://www.nabble.com/Mapguide-server-is-very-slow-tp20969356p21026651.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Mapguide-server-is-very-slow-tp1646446p1661341.html
