[mapguide-users] Problem opening a webLayout with predefined
selection
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Dec 17 05:06:59 EST 2008
Nice idea.
You could do the same with the runtime map, which would ease the
pre-creation/modification of maps.
If the user presses the reload button, the map would stay the same, as
would the selection.
Is this a problem, and do you have and idea for a workaround?
Regards, Kenneth Skovhede, GEOGRAF A/S
Bruno Scott skrev:
> I could propose a patch to fix that problem
> The idea would be to verify if the Session://...MapDefinition exist
> If it already exist, do not overwrite
> Something like this
> bool mapStateIdExist = true;
> MgResourceIdentifier mapStateId = new
> MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." +
> MgResourceType.Map);
> try
> MgByteReader tmpReader =
> resourceSrvc.GetResourceContent(mapStateId);
> catch(MgException mge)
> mapStateIdExist = false;
> Then use the mapStateIdExist flag
> //if MapStateId exist, we should not erase the selection
> if(!mapStateIdExist)
> //create an empty selection object and store it in the session
> repository
> MgSelection sel = new MgSelection(map);
> sel.Save(resourceSrvc, mapName);
> and
> //if MapStateId exist, we should not overwrite it
> map.Save(resourceSrvc, mapStateId);
