Re[mapguide-users] trieving Ajax viewer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Dec 17 07:07:40 EST 2008
Just create a weblayout with nothing visible (the map is obviously
always visible).
Then you can provide all the stuff you want from Visual Studio (buttons,
menus, etc.).
The setup is the same as described in the developer guide, but the
toolbar, etc, won't be visible,
and you will have to create it yourself.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
>    Hi,
> Thanks for u r reply.
> But  iam using new visual studio web solution.i want this ajax viewer only
> in my web page
> How is it possible?
> Thanks and Regards,
> Padmini
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You can remove the toolbar and others, in the WebLayout, using Studio or
>> Maestro.
>>>   Hi,
>>> Iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1) by using ajax
>>> viewer .
>>> Now i want to get only ajax viewer  not all the toolbars,taskpanes all
>>> these
>>> things.
>>> i found that this map pane retrieved from the ajaxmappane.tmpl(from
>>> www/viewerfiles) but i didnt get the exact code for retrieving only that
>>> ajaxviewer.
>>> can u tell me the procedure(code for calling this mappane only) to get
>>> only
>>> that ajax viewer.
>>> Thanks and Regards,
>>> Padmini
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081217/38148dee/attachment.html
