Re[mapguide-users] trieving Ajax viewer
padmini godavarthi godavarthi.padmini at gmail.com
Wed Dec 17 07:59:22 EST 2008
Thanks
I tried it.But empty toolbar strip was displaying on the top of the
mapframe.at the left side also i dont want the legend control and properties
diplayer. i want only that ajax viewer panel which displays the map.
can u give me the suggestion?
Thanks and Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Just create a weblayout with nothing visible (the map is obviously
> always visible).
> Then you can provide all the stuff you want from Visual Studio (buttons,
> menus, etc.).
> The setup is the same as described in the developer guide, but the
> toolbar, etc, won't be visible,
> and you will have to create it yourself.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>>    Hi,
>> Thanks for u r reply.
>> But  iam using new visual studio web solution.i want this ajax viewer
>> only
>> in my web page
>> How is it possible?
>> Thanks and Regards,
>> Padmini
>>> You can remove the toolbar and others, in the WebLayout, using Studio or
>>> Maestro.
>>>>   Hi,
>>>> Iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1) by using
>>>> ajax
>>>> viewer .
>>>> Now i want to get only ajax viewer  not all the toolbars,taskpanes all
>>>> these
>>>> things.
>>>> i found that this map pane retrieved from the ajaxmappane.tmpl(from
>>>> www/viewerfiles) but i didnt get the exact code for retrieving only
>>>> that
>>>> ajaxviewer.
>>>> can u tell me the procedure(code for calling this mappane only) to get
>>>> only
>>>> that ajax viewer.
>>>> Thanks and Regards,
>>>> Padmini
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Retrieving-Ajax-viewer-tp21033982p21052681.html
